Jeff Morgan
Active Member
Drilling equipment onsite
Nope. If you excavated to a P3 level (for example) and built a 10 storey building, that's going to weigh significantly less than excavating to a P3 and building a 40 storey building (or 50 or 80 etc.).I remember reading once that the weight of the earth removed is roughly the weight of the skyscraper that is built on top of it so the two basically cancel each other out. True?
Does this mean the status will finally get changed to "under construction" in the database?
I think you're thinking of buoyancy calculations, the weight of water displaced equals the weight of the boat."For every action there is an equal and opposite reaction"
Mexico City is probably a better example, but this has to do with soil quality. The buildings would likely sink regardless of "how much soil is removed" from the excavation, so long as their foundations are inadequate for the "soil" they rest on.Also to add, there are cases where cities/areas are literally sinking partially due to the sheer amount of pressure their buildings place on the earth below. New York is a famous case of that:
New York sinking under its own weight: study
If New York is the city that never sleeps then how's this for keeping you up at night? It is also sinking.phys.org
