Second_in_pie
Senior Member
So you're expecting stops at East Mall, Sherway, Dixie, Stanfield, Cawthra, Central Parkway and Burnhamthrope at the least? Unless you're going to put in all those stops, a subway really is completely redundant.Did I not just say that?
I really want you to look at this for a second. What is there between MCC and Sherway that needs subway? If you want something that connects MCC to the rest of the city, the Milton line is really what you want. It would provide a fast connection to Sherway, Etobicoke, and Downtown. It'd be cheaper than subway, with no downsides compared to subway. Regional Rail is already there anyways, and is going to be getting better even if a subway is there.
What exactly is it about the Milton line that you don't like? Is it just the fact that subway has prestige that regional rail doesn't? You do realize that the Milton line would be basically be the exact same as a subway, right?
It's not TTC for Torontonians. Well it's not subway for Torontonians at least. The subway's going up Yonge because there's density along the entire route. NYCC-RHC with over 50k people in between. For Vaughan, VCC is only 2km away from Steeles, where it would make sense to end the subway because York U ends there. But with VCC being built less than 2 km north, which will be a high density centre housing thousands of people and thousands of jobs, well... you do the math.TTC for Torontonians. Except in special exceptions such as York Region. Right.
Somehow a subway to York Region is win-win, whereas a subway to Mississauga is what, lose-lose? Improving convenience is somehow bad?
Because there's nothing at VCC it's easier to build there? That's a reason to expand the subway there? Are you fucking kidding me?
Also, the Richmond Hill line just isn't the same calibre of convenience as the Milton Line. The Richmond Hill line bypasses NYCC, Yonge and Eglinton, as well as Bloor-Yonge, while the Milton line goes from MCC straight to the end of the B-D. The Barrie line really isn't anywhere close to VCC and would have to be rerouted over 10 km, probably mostly underground. Rerouting the Milton Line straight under MCC would be less than 6km, and depending on the route only 2 km underground and 4 above ground. Putting the B-D to MCC would also be 8 km from Sherway.
