Toronto Rogers Centre Renovations | ?m | ?s | Toronto Blue Jays | Populous
The A-shaped wings are needed to support the roof once it opens- you can see it in your pictures how it supports a rail on top. I would definitely say that the hotel should be removed- especially once Union Centre gets built, it'll allow the building to essentially 'open up' onto a gigantic green space.
Also definitely wonder how much of the 3rd level stands can be removed to punch openings into the upper levels- a clerestory level could work well there in bringing in natural light and sense of the surroundings.
Source
Interesting note from a year ago- I did recall seeing something like this a while ago.
Perhaps that's obvious, given the talk about extending the building's life by 30 years, but what would that even look like?
A source with knowledge of proposals made by an architectural design firm working with the Blue Jays on the project told The Athletic it would be a “dramatic reconfiguration.” For example, one consideration is to rotate the entire field clockwise. In this scenario the Flight Deck would now sit along the left field line, and when the roof is open the CN Tower would be in view as backdrop for fans sitting behind the plate. The giant video scoreboard that's now in centre would remain, helping to break the too-symmetrical cookie cutter nature of the current setup. To that end, the fence line in this reconfiguration could change to have a bit more “real ballpark” character, and the area that would become right field might become an open concourse — something that is perhaps made possible by the fact that there is still room on that side of the building to expand its footprint to the east. (The source adds that, were they to do this, much would need to be done to reconfigure the roof for sunlight/shadow reasons, but tells me that there is a solution for this.)
Rotated field or not, not only does reconfiguring and upgrading the building's seats seem to be a given (having all seats actually face the action on the field would be a huge improvement), but openness seems the order of the day, whether that be more patio spaces like the ones at Petco Park in San Diego, or simply by widening concourses by expanding the building outward and removing seats. Interestingly, the source adds that another large part of the plan involves making the Dome a destination that can generate revenue during the offseason. This doesn't mean more Monster Truck rallies, but by making the Dome a destination people go to when the Jays aren't playing. For example, one of the things that was pitched was to open/run local restaurants throughout the 200 level to give the ballpark a more “Toronto” feel.
What's old seems to become new again:
Also:
They were actually considering doing this (cutting open the dome) on the gate 5/6 side. There's talk about making it a huge atrium with views from outside to the field. I don't know if it's still being considered.
Costing of potential renovations vs. the actual cost at finish is usually higher. Weighing that against a new building can be a conundrum. Spend $250-$300 mil on an old building, and still have an old park with a new face, or build a new park.
Rogers will have to answer to the share holders, and we know how that will go. I expect the tired old park to get a facelift, but it will still be a somewhat outdated and old, and 10 years later this whole conversation will re-emerge.
Also:
If Rogers goes the big renovations route, I'd be on board with rotating the field.
What we really need is a rotating stadium, something on a rotating center bearing. Just press a button and the stadium spins 180 degrees. Press another button and the stadium turns into a giant centrifuge.
$250-350M for a park that still won’t likely be able to support natural grass. That’s another major piece of the puzzle given MLB’s priorities, as well as attracting players who don’t like playing on fake turf.
I’d prefer to leave the field in its current orientation. The current setup has nearly perfect symmetry.
But is symmetry especially important in baseball? Most stadiums include some type of design quirk just to add character.
Right now, if you're behind home plate, you're facing the jumbotron and hotel, and the large, dark, shell of the dome. By rotating the field, you would see the CN Tower as the backdrop, which I think would be pretty cool.
If playing on natural grass is an MLB priority - why did they allow Arizona go back to synthetic turf?
I doubt it an MLB Priority but the players do prefer it and it is one of the reasons most players do not want to come here.
The problem is that it is hard to maintain turf in the current stadium. It was never designed to have real grass and as such the infrastructure for an irrigation system was not installed. Also, it is a multi-use stadium and as such it is hard to put a full field of grass there without having to hire a grounds crew.
One of the most important reasons we do not have grass is our weather. Grass does not grow well indoors and the stadium has a domed roof. Yes you can open the roof but it is not open permanently to allow sunshine, rain, etc to foster the development of real turf.
Stadiums like Wrigley, Fenway, Progressive Field are all open air and single use for the most part (Baseball only). They are not used very much in the winter if at all. In order to have real turf, you need to rebuild the stadium and make it Baseball only.
Rogers Centre still has a lot of life left in it. An upgrade of that magnitude along with development of surrounding area should give it quite a few decades.
Building a new stadium may seem like a great idea, but the current location is practically perfect.
Ugh? maybe the structure itself has but apparently everything else doesn't or they wouldn't be talking about what to do with it,
..it just might not be feasible to spend 200-300 million dollars to renovate and upgrade something on land they don't own
It's feasible. They may not own the land, but they own everything else. Owning the team, stadium and the broadcaster that does their games puts Rogers at a special advantage among other owners.
Spending $300 - $400 million to upgrade the Rogers Centre probably makes more sense than finding new land and building something from scratch. The new/improved revenue steams alone should make it worth it over time.
Land costs are definitely an issue regarding any new stadium, the only real place I could see them headed to (even temporarily) is the CNE grounds, or maybe Downsview or the Portlands- and all of those are far more poorly serviced and located than the current space.
it's the media who is stirring the pot, not Rogers. And the media is doing it because the team sucks and they need content.
The asymmetry of most parks has always seemed odd to me. I prefer good balance and proportions. Realigning the field would be a major waste of money and is completely unnecessary. I’d prefer most money going toward exterior and interior upgrades (aesthetic). One of the articles I read was in favour of turning the field to a northeast position, merely to break the symmetry of the current layout and copy the off-center style that is common in other ballparks. That just seems like a really bizarre reason to go to such lengths for a pretty pointless feature.
If the field were to be rotated, the view of the CN Tower might feel too imposing from that proximity. It would loom over the field. Right now, the view of the CN Tower can already be enjoyed by many in the stadium, but it is off to the side and one can choose to ignore it, if they wish. It might be a bit overwhelming if the field rotation were to come to fruition, as it would dominate the backdrop in a formidable way.
The rationale for rotating the field clockwise is to create a new outfield entrance and fan area. Gates 5 - 6, which are currently entrance ways to 1st base, would become the new outfield area as would the existing square in front of the CN Tower. I would imagine that new outfield area would be far more open with views of not just the tower but downtown as well. Any potential new rail deck park would integrate with a new fan space and entrance to the stadium on the left field side where the Jumbotron currently is. Field rotation would also allow for full reconstruction of the lower bowl seating arrangement which is badly needed.
