emphurent
Active Member
This is what the architectural docs show for the back. It's very spandrel heavy, but frustratingly inaccurate on the usage of mullions which was something I had a worry about. Cheap window wall systems look cheap because of the thickness and density of use. In this case they chose a thicker cheap system. Unfortunately while the documents I posted before showed very nice materials, the mullion system is not defined... so it's a wait and see situation on each material section.
Furthermore, the mullions here are supposed to be black? according to the material list to the city. These documents give far too few insights into materials or straight up lie, so don't trust the connecting system until applied here (at least I hope they don't look as bad) which was why I posted the other materials (who knows what was cheapened though without specifics). The mullions are specified as being used commonly on there as labeled at window wall system (not specifically unless it's by Toro Windows)
The mullions here appear to show curtain wall on the front, and the glass on the documents I posted a while ago was also specified to be curtain wall. This very much could be ruined by thicker cheap mullion use.
The black sloped metal being used on the towers is not cheap, I can guarantee that having seen it. Understandably though this building could suck if they only spent well on certain aspects of the tower. The towers use regular window wall, not curtain wall, keep that in mind. The renders are not truly accurate, even as much as I wish them to be (curtain wall was just a better idea, but it's clearly window wall supplied by Toro Windows)
EDIT: This is specified for the front specifically.
