LemonCondo
Active Member
What is the situation along the transitway as far as TOD goes? Even if its a mix of residential, commercial and office, still should be TOD. Right now all I see are suburban office parks with seas of parking.
The Transitway is in an ROW of an hydro corridor, transmission lines for gas and oil. This rule out TOD. To the north you have low density to mid rise buildings. and see no increase for it.What is the situation along the transitway as far as TOD goes? Even if its a mix of residential, commercial and office, still should be TOD. Right now all I see are suburban office parks with seas of parking.
Highway ROWs are fine if you treat them as they are, connector lines. Rather than lines where people work and live on, they're lines where people connect to for Orbital travel. This plays into the most common misconception of Transit that ridership depends on nearby development walking connections which simply isn't true, and Toronto is one of the biggest examples of this.This is why I am dubious of highway ROW transitways. We should reserve separate ROWs for rail transit...
Provincial visioning indicates this would become a part of (what I call) the nu-transitway, which is set to have some sort of rail service (“LRT”) instead of BRT. It’s almost the same alignment, but instead of going north following the 407 from the 407/403 in Oakville, the line will follow the 403/Transitway to MCC, Pearson and then link up with the 407 again via the 427 or hwy 27.What are the chances that this line gets extended a bit one day to link up to the future 407 transitway?
Zero as it stands today and 20 years plus down the road based on current ridership numbers if at all. It's a GO thing.With the Hurontario LRT going to the City Centre, how likely will this be studies to convert it? Or, will this potentially stay a transitway into perpetuity?
As noted above 427 or 27 with MTO saying no to the 427 like it has for years south of the 401. This leaves Hwy 27 for the transit connection to Hwy 407What are the chances that this line gets extended a bit one day to link up to the future 407 transitway?
Sounds like we need to wait till the Crosstown line is built, and potentially the future extension of it to the airport before any though o doing anything more with the transitway is done.Hopefully, if a conversion is done, it is not as painful as it was in Ottawa.Zero as it stands today and 20 years plus down the road based on current ridership numbers if at all. It's a GO thing.
If it is decided by the province to have a branch line off the Eglinton Crosstown Line, the existing Transitway is built to run both LRT/BRT but would require the shutting down of the transitway to build one direction at a time or both to do it. Then there is the option of tunneling it at great cost and timeline and building access to the existing stations.
You have the missing sections from the eastern section to MCC that was to be tunnel under Hurontario to CCTT, but Hazel did not have the $20 million to do it at the time. Then there is the tunnel or overpass from CCTT to the northside of 403 and then the ROW from Mavis to Erin Mills that was supposed to see two more stations added to it.
The plan that is on the book is to see the extension go west from Winston Churchill by Hwy 403 to Hamilton and not build the Ridgeway Station as planned. Ridgeway was removed when that section was built due to poor numbers for it.
The original plan to go east was to use the hydro corridor on Hwy 27 to Sheppard and then follow the Sheppard Hydro corridor across Toronto that is now dead since Hydro One wants to protect the corridor for future expansion for it.
My understanding is that the Transitway was built with upgrade to LRT in mind. Not sure exactly what that means, but I would hope it means its pretty painless.Sounds like we need to wait till the Crosstown line is built, and potentially the future extension of it to the airport before any though o doing anything more with the transitway is done.Hopefully, if a conversion is done, it is not as painful as it was in Ottawa.
I thought that was also said about the ones in Ottawa too. Regardless,we won't know for at least 10+ years as we need to wait for both the Hurontario LRT and the Crosstown West LRT are done.My understanding is that the Transitway was built with upgrade to LRT in mind. Not sure exactly what that means, but I would hope it means its pretty painless.
I mean it’s true in both cases… it’s just that that only really means that the corridor geometry will accommodate rail.I thought that was also said about the ones in Ottawa too. Regardless,we won't know for at least 10+ years as we need to wait for both the Hurontario LRT and the Crosstown West LRT are done.
Wow, setting the bar really low.I mean it’s true in both cases… it’s just that that only really means that the corridor geometry will accommodate rail.
