I can't say I look at those thin walls filled with dirt and think "this is going to last 100 years". Hopefully under this dirt they are running weather resistant tensioning wires between the two walls to hold them together a fixed width.
Those vertical pipes are an interesting new addition. Maybe Metrolinx news will explain
They’re MSE (Mechanically Stabilized Earth). The thin walls are not actually structural, it’s the dirt/sand holding the weight. Reinforcement embedded in the dirt holds the dirt together. It’s the same stuff used on highway ramps, some retaining walls, and the like. It’s actually a pretty interesting technology.
Mechanically stabilized earth - Wikipedia
en.m.wikipedia.org
There's historical photos showing that this is how the embankment for the CN mainline from about Pape to Union Station was constructed back in the 1920s (and 1930s?). You can also see photos of this being how streetcar tracks and roads were built across some of the ravines that were filled in - such as Upper Gerrard Street.This is how many railway embankments were created. Often, the railway would cross a valley or gorge on a simple wooden trestle. Trains would have to go slow and light, but it’d get revenue started quick. Over time, earth would get dumped between the wooden lattice, eventually making it as strong as level ground, allowing higher speeds and heavier loads and locomotives.
Ok, so there is a horizontal tensioning element (i.e. soil reinforcements) both holding the soil together horizontally and holding the wall against that soil. I guess in the pictures any of those soil reinforcements have already been covered with compacted dirt.They’re MSE (Mechanically Stabilized Earth). The thin walls are not actually structural, it’s the dirt/sand holding the weight. Reinforcement embedded in the dirt holds the dirt together.
If it means the same as it does in Australia then it would be Traffic Classification. T6 are rated for a maximum tangent speed of 80 km/h.
That's absolutely not the case here. The type of tie has no bearing on the speed limit of the track.If it means the same as it does in Australia then it would be Traffic Classification. T6 are rated for a maximum tangent speed of 80 km/h.
Source: https://www.transport.nsw.gov.au/system/files/media/asa_standards/2019/spc-232.pdf
