innsertnamehere
according to NRU, this has reached a settlement with the city. Height has been reduced to 44 floors and 145m. Section 37 goes towards the YMCA on Brant Street.
Ah, reporting on the results of the OMB hearing on Feb 21. I suppose it became a ratification meeting for the settlement. I'll look forward to the full decision being posted.according to NRU, this has reached a settlement with the city. Height has been reduced to 44 floors and 145m. Section 37 goes towards the YMCA on Brant Street.
Will it be the same style? We'll have to see; the last version was 11 storeys taller, and besides a shorter height, we don't know what stepbacks the building will be required to adhere to, maximum GFA, etc. It could end up being anything from simply lopped off 11 storeys sooner but the same design otherwise, all the way to completely different. Most probably something in between…It's ok for 45 storeys.
But,will they keep the current design of the building ?
I hope they will because the current design is pretty .
It looks like this may end up 2 metres shorter than Bisha at the other end of the same block, unless the 145 metres does not include the mechanical penthouse. 357 King West, just north of Bisha, will be about the same height too.^I agree with u my friend. they should not change the design. + the city should have reduced it to 165 - 170m. 145 is very short. how tall are the buildings in the neighborhood? will it stand out among other buildings in the neighborhood?
The OMB has single highhandedly been destroying neighborhoods in this city for numerous years, and this simply has to come to an end. Does anyone know when the province's review of the organization is due to be released?
The redevelopment proposal now before the Board reflects a settlement between the parties and is a substantial revision to the proposal that initially formed part of this appeal. The revised proposal is to construct a podium and tower on the subject property with a mix of commercial retail and residential uses that would include, among other elements:
- a. a maximum height of 145 metres (“m”);
- b. a maximum of 41,300 square metres (“sq m”) of gross floor area on the lot, of which a minimum of 1,460.70 sq m would be non-residential uses;
- c. a minimum of 10% of the dwelling units on the lot having three or more bedrooms; a minimum of 1.5 sq m of indoor residential amenity space per dwelling unit and a minimum of 0.9 sq m of outdoor residential amenity space per dwelling unit on the lot.
[12] On consent of the parties, the Board allows the appeal in part, and generally on the basis of the Draft Zoning By-Law Amendment entered into evidence as Exhibit 6.
[13] The Board withholds its Order approving the Zoning By-Law Amendment until the pre-conditions set out in Attachment 1 are satisfied.
Man, do the issues surrounding the OMB ever get partisan, either completely on one side or the other. Is it truly that difficult to see that there are both benefits and issues that are created from OMB decisions? As is often the case, a middle ground, pragmatic, non-emotional type of regulatory reform would be great. A refinement of the regulations that guide OMB decisions, if you will. That will both guide and approve development growth, while being sensitive to locational contexts. Clearly local groups are not viewing the issues of scarcity in a large enough, or forward thinking enough way, while it seems the OMB at times can overstep or create unforeseen precedents that may be somewhat too high/large. Am I missing anything here?
