fanoftoronto
Active Member
Where are your sources that my numbers are wrong? At least I have numbers to back up my claims.
Its about not building lines that are incredibly silly in design right off the get go. Most people unfamiliar with the line look at it and start banging their heads on the desk.
North American Agencies CONSISTENTLY underpredict ridership numbers. The King Streetcar Pilot brought in more new riders than predicted. The various new GO services that were launched in the early to mid 2010s such as the Niagara Excursion train overperformed. The Canada Line brought in more riders than their numbers predicted. iON flew past their ridership projections, and so did the Confederation Line in Ottawa. Not trusting the agency's ridership numbers should be the status quo at this point.
Only one thing I'm going to respond back. You're bringing the numbers, you need to bring the sources for the numbers. I don't have to prove your numbers are wrong when it's literally pulled out of thin air.
Marco Chitti recently posted an image to twitter that compared all the costs of guideways and tunnels. Unfortunately its in euros and likely assumes European construction costs which are much lower than here, but we can use it as a general guide:
Now originally I wanted to go in depth into every cost and try to figure out how much an elevated station would cost with left over money, but that's a virtually impossible task since we have to make assumptions about different construction costs, inflation, currency conversion, small details in projects like underpinning, bridges, utility relocations, which would require so many assumptions that the numbers become meaningless. However I will give the following conjectures to chew on. At 14-35M Euro per km for a twin bore, assuming the highest number that's 47.25M/km that it costs to tunnel. At station costs of 200M per station, that means that 1 station costs the same as 4km of tunnels. As such, when you are building a subway at 1 station per km, 4/5ths of the cost is dedicated to just the station. Immediately, any decrease in cost of the station means a lot of savings in the long term. If we assume that a 50m long station costs 5/9th as much as a 90m station (probably doesn't, but its the safest guess I have), that leaves us with 160M/km instead of 250M/km. The Eglinton Line's tunnel segment is 11km long, so over 11km you save $990M on shorter stations, which is enough to pay for 50km worth of guideway, if we look at the 14M euro/km option. Now I also suggested building 6 elevated stations (I am excluding Leslie since that could be built at grade on the south side of Eglinton), and at 5.4km of elevated guideway, we have it cost 105.1M. That leaves us with around $885M left over for the stations. With 6 elevated stations, that leaves us with 147M per station in our budget - which is certainly doable. While I cannot comment on how much cheaper elevated stations are, this calculation gives us with an estimation that allows room for elevated stations that are almost as expensive as 20m deep stations.
If you want to argue some of the assumptions I made, go ahead. However keep in mind that these smaller station calculations completely ignores Kennedy and Science Center. With the exception of how much reduction we can have in the cost of stations, I have made mostly "worst case scenerio" guesses - since we're moving to Light Metro technology, we could for instance run a 3rd rail light metro train like the Canada Line which will permit us to use smaller tunnels which will save money. Realistically though, not only do you have to show that the savings do not permit an elevated section being built, but that its SIGNIFICANTLY MORE EXPENSIVE to go the light metro route. I'd be willing to argue that an elevated eastern section of Eglinton could be 1.5x as valuable as the LRT and would accept a project costing as much.
Here are your incorrect assumptions and incorrect sources.
- Elevated viaduct cost of 14 million Euro per km when at-grade LRT costs $100 million per km? More like $150-200 million per km for elevated viaduct. A random Twitter page with a fancy picture and European numbers is not an actual source for transit construction cost in Toronto.
- Twin bore tunnel costs 14-35 million Euro - Taken from the same incorrect source that said the elevated guideway is 14 million Euros. Just boring the tunnels themselves probably takes $100 million per km.
- You assumed a 50m long station would cost 5/9th the cost of a 90m long station. Where is your source?
- Ignoring the fact that the above issues makes the $990 million total savings and $885 million remaining for stations just plain false. You stated $147 million per elevated station is certainly doable. Where is your source for that?
As with @DirectionNorth I'm not gonna argue this any further. Let's just agree to disagree and call it a day.
