sixrings
Senior Member
still no definitive answer to the question...if there is enough spacing does it need to be elevated to be interlined?
Slowly but surely, this line is getting 100% grade separated. With Miller out of the picture who absolutely wanted the LRT on the streets, they aren't going to meet any opposition to make it a "metro" line.
How would they know where to rough it in? Would you put it above or below the Eglinton line (soil conditions blocks north and south of the station determine this)?
Do you put it at Don Mills or try for a 3 way interchange with a potential mid-town GO line a bit to the west of Don Mills or north of Eglinton?
A DRL running along O'Conner and north on Vic Park would eliminate a ton of "how do we get lots of busses/lrt over/under the DVP"" problem. Don Mills isn't a great choice if most ridership is transferring to it from the East.
A DRL along O'Connor and Vic Park would miss 3 major nodes: Thorncliffe, Flemmingdon, and Science Centre.
I believe that DRL must serve those 3 nodes. And if it does that, I don't see how it can miss the Eglinton / Don Mills station.
Furthermore, a DRL station at Eglinton / Don Mills would utilize the same LRT station and bus terminal that will be built for Eglinton LRT.
If DRL is ever extended north of Eglinton, then veering it east to Vic Park can be considered; but not south of Eglinton.
Considering they somehow failed to notice the development east of Brentcliffe that's been advertised for YEARS even with the LRT in their on street ads I wouldn't put much faith in their ability to plan for the future.
And I would assume that a similar situation would exist in the west once the line is extended there, hence my suggestion of 'mirroring' the terminus stations.
Except that the original EA had half of the trains turning back at the west end at Keele with a pocket track west of the platform - passenger levels dropped off significantly west of there. Considering this EA amendment only covers the section west of the portal (and thus west of the pocket track), I think that it is safe to assume that those plans have not changed.
What I'd also like to see is the Jane bus detour via Weston and stop at the Mt. Dennis hub, then jog back out on Eglinton West and then continue down Jane. That would dump a significant number of passengers off at that station, instead of having them travel down to the Bloor line (it would likely also be faster for them if they're heading downtown).
The current plan is to make Mt Dennis the southern end of 35 Jane and the northern end of a new route called 19 Jane South.
Who Metrolinx listens to is open to question. The TTC and the City were conspicuous by their absences at the Tuesday meeting, so one has to wonder whether there might already be friction between them, and, accounting implications aside, if it's really such a good idea in the long-term to have Metrolinx running local Toronto transit projects rather than the TTC.Slowly but surely, this line is getting 100% grade separated. With Miller out of the picture who absolutely wanted the LRT on the streets, they aren't going to meet any opposition to make it a "metro" line.
I like that Metrolinx seems to LISTEN to the population while Miller and Giambrone wouldn't listen to anyone to protect their pet project.
Which, just to throw in a minor detail, he lobbied against.Under Miller the subway to York U was started.
For what it's worth, a Metrolinx rep stressed to me at the Tuesday meeting that the line will definitely end at Mt. Dennis rather than Jane.Seems, from the people answering my questions, that "Mt. Dennis" could be the western terminal for phase one of the Crosstown because of the use of 15 bus bays. "Jane" may no longer be the terminal, but I need to see better clarification on that.
Which is great, but there is a risk of (further) overloading Yonge.I just think that overall this line has the opportunity to take a lot of pressure off the Bloor-Danforth line.
Getting a DRL to the B-D line (Pape or wherever) will be hard enough. Barring Federal funding, getting it to Eglinton within 15-20 years will be next to impossible.The bigger problem when it comes to pouring passengers onto an overcrowded line is in the east, which is what the DRL transfer at the Science Centre is supposed to solve. In fact, I'm actually kind of thankful for the Eglinton line in this sense, because it's going to make the DRL even more imperative, because the cluster**k is going to move its way even further north as a result of the ECLRT.
