 1.1K     0
 999     1
 371     0
I'm kind of learning about this kind of transportation, but couldn't they make the streetcar go UNDER the intersection. But I guess that would defeat the purpose of even having an LRT on the surface route.
They certainly could, and many of us think they should. Also, it's common for many surface-running LRT systems in the world to grade-separate busy intersections to minimize the rail and road's impact on each other, without necessarily needing to build more expensive full tunnels or viaducts.
Is Brentcliffe all that much worse than Laird for a stop?
Yeah, Laird is a bigger street, but I note that Brentcliffe has much more apt. housing, and may have more space for a stop too.
The main problem is the bus routing, but would it be easy to reroute the buses to compensate?
The problem with Brentcliffe, is that there is virtually nothing further east. So while those who are right at Brentcliffe might be inconvencienced to walk to Laird, there is virtually no one who isn't at Brentcliffe, and is further east, who would be inconvencienced. Though between the apartments along Eglinton from the NW corner of Laird, and the big building on the south side of Eglinton east of Laird, I thought there were more apartments closer to Laird than Brentcliffe.
Exactly, nfitz. I'm willing to support the Eglinton LRT because I don't believe we necessarily need a full subway in this corridor. That said, the TTC's own travel time figures for the surface section are terrible. And they haven't even started construction, so they can only get worse. I just can't fathom why (Well, I can but I don't like it) the TTC steadfastly refuses to look at any other cities as a model of how to run proper light rail. I'm not even talking about Europe here. Calgary is a perfectly good model of how to run light rail in a suburban corridor like Eglinton. With the travel times the TTC has shown us, any and all travel time savings on the surface section compared to the existing bus are coming from less frequent stops. That means this thing is going to be stopping at every traffic light. This just makes absolutely no sense. Run a bus with less frequent stops and you've accomplished exactly the same thing for 1/1,000 the cost.
I really don't see a problem with cut-and-cover. Eglinton has lots of room.
Really???
Other than the centre section that has to be tunnel, there is room to do a cut and cover for the rest. But then, most of it will be on the surface in the first place.
There is a fair amount of stuff east of Brentcliffe (apt. buildings and houses on the north side and townhouses on the south). However, it's not at street level and much of it is hidden by trees.
