canucks83
New Member
Because Ontario doesn’t seems to know the difference between Rapid Transit and Mass Transit. At the end of the day it’s better than nothing but wish Toronto had more vision.So why was this billed as rapid transit?
Subways are also great at bypassing traffic while still being able to travel at high speeds. So are BRTs.Here's another video showing the LRV versus traffic, which is a better comparison than speed alone.
Because anything is possible when you use your imagination!So why was this billed as rapid transit?
Looks a lot faster than 22 km/hr in that video above. I doubt the average would even be as low as 22 km/hr between Leslie and Kennedy. And probably similar to the subway over the whole line, hitting the low 30s.It's almost definitely going to run slowly, based on the test videos. My guess is that it'll be run like the streetcar, and even with the ROW, the operator will still randomly hit the brakes every so often lest the LRT exceed 22 km/h.
It would be nice if people here waited until the line was actually opened and they had a chance to actually observe its operations rather than making quick value judgements based on short Twitter clips.They are, after all, testing.... maybe the point of the exercise is simply the number of vehicles on a controlled headway rather than full speed operation?
When I have been out that way, I have certainly observed single tramsets running at respectable speeds.
Maybe there is more to come.
This is the world we live in (unfortunately):It would be nice if people here waited until the line was actually opened and they had a chance to actually observe its operations rather than making quick value judgements based on short Twitter clips.
I would assume 22 km/h figure would include time at stations/stopsLooks a lot faster than 22 km/hr in that video above. I doubt the average would even be as low as 22 km/hr between Leslie and Kennedy. And probably similar to the subway over the whole line, hitting the low 30s.
I was thinking about this the other day, with the number of scam calls you get anyways now, its probably come full circle where the phone book might actually be worthwhile again in the event someone actually does need to contact you these days.How many people want their cell phone number in a phone book today?
Those clips out there don't show every single train. And every single train is being operated by a different operator, that may have a different set of criteria upon which they feel comfortable running right now.There have been so many test videos to date showing line 5 being operated like a streetcar on the surface section that it's hard to believe it will run at a speed most riders would consider rapid. Why the LRT doesn't appear to be running anywhere close to the speed limit is confusing to me. But I do think it will be a much nicer experience than the bus in any case.
Finch West / line 6, which is a 10.3 km line, will take 34 minutes end to end. That's an average speed of only 18km/h. So hopefully line 5 will run a lot faster along the grade-separated sections to make up for the slow surface section.
What's been promised is a "rapid transit" line (source: https://www.metrolinx.com/en/projects-and-programs/eglinton-crosstown-lrt ).I don't recall anyone promising a bullet tram.
We don't have the detailed calculations in hand, but my observations suggest the line has been built with adequate track speed, but considerable impediment at intersections due to the traffic signalling and the need to observe station stops. To date, when I have seen trams testing, they seem to consistently assume fairly lengthy platform stops, simulating a worst-case load/unload scenario. There are certainly hints that the line has been timed cautiously, and it will after all be the TTC operating it.
It's quite likely that the line may operate slowly at first, leading to customer and public pressure to do better. That pressure may be more effective than us transit wonks crying about it ahead of time - the line may have to be a work in progress.
The other part of the issue for me is that there is very little provision for pedestrians crossing over at other than major arteries, ie pedestrian crossings are very far apart. The new Eglinton is far from a walkable street. The temptation to take short cuts is out there. We may not want 80 km/hr line speeds, as nice as that may sound on paper.
OP was referring to the actual velocity. Not the average.I would assume 22 km/h figure would include time at stations/stops
