News   Jul 26, 2024
 929     0
News   Jul 26, 2024
 2.5K     2
News   Jul 26, 2024
 2.2K     3
I decided to take the signal priority issue directly to the crosstown team and here's what they had to say.
"Thank you for your interest in the Eglinton Crosstown project. With regards to signal priority, please note that limited priority (request for extended green, or early green if a train is behind schedule) along the Eglinton Crosstown was the finalised agreement with the City of Toronto in the development of the project specific output specifications (PSOS). Unfortunately, at this stage, no further changes will be made."
No chance of real signal priority ever. So except for the track gauge, and the coupled trains, what's stopping us from calling the surface section a streetcar line?
Good on you for taking the issue to Metrolinx, nice work.
So as we can see not only are we not going to see signal priority because of Toronto's inept and pathetic planning, but if we ever want to revisit the issue of signal priority, the city would have to reach an agreement with Metrolinx to implement it. Looks like that's the final nail in the coffin for that, because there's no chance the 2 of them will ever reach that kind of agreement the minute that trains start to roll.
Of course if we actually had some leadership over at city hall, they could still reopen the issue before the scheduled 2022 opening. However seeing as we have no real leadership in this city, i'm not holding my breath on it at all. Once the clock hits 2022, there is a 0% chance Eglinton will ever see signal priority in any our lifetimes.
Without proper signal priority, they'll probably eventually remove it from the map altogether. The map used to show the "Harbourfront LRT", but it was subsequently removed.
I doubt it as it's being branded differently, just because a few people, a message form don't consider it rapid doesn't mean that it shouldn't be on a map. I tried to make the argument that the airport rocket shouldn't be on the subway map but it's been on to longer than the 604 harborfront was, part of it leaving was probably due to the line being extended to Spadina and becoming 512 Spadina and then later the 509 harbourfront extension to Exhibition
It's essentially the new design language being pushed by Metrolinx for Eglinton, Finch, and Hurontario. The boring white and black finishes, the font, the symbols, the diagrams and bilinguality. Personally, it's nice and minimalist, albeit a bit boring.
This should be the actual rapid transit map. Emphasis on rapid, because you know...
I think the map should still show the full Crosstown, but show it differently for the above ground portions.
Like change it to an outlined line to indicate its different, and remove the station stops but show it still continuing to Kennedy.
I mean the map shows a bus to the airport FFS.
Boston's Green Line shows different thicknesses for surface or subway, but is still classified as "rapid transit".
From link.
From link.
This would just add unnecessary confusion to the public. The system map is designed for navigability not technical correctness. Although the LRT lines would be slower, they are designed to integrate with Subway/RT system with underground connections at Kennedy (Line 5) and Finch West station (Line 6). They are designed to move more riders than the local streetcar/bus with more frequent services.
In terms of speed, the downtown U is probably comparable to the surface LRT sections during rush hour because of all the additional dwelling time and 500m stations apart. Should a map be designed to indicate slower subway?
Unless the media picks this up and starts calling this an expensive white elephant project, I doubt city hall would ever take this seriously.
The media might do that after it opens. A similar line opened in Minneapolis a decade or so ago and there were complaints and media stories about the red lights and general slowness. That being said, Minneapolis has another line that has proper full priority like Edmonton so they actually know what proper LRT can be.
And the actual train that goes directly to the airport is nowhere to be found.
You mean like this?
Instead of spending $5.5 billion on the Eglinton Crosstown, we could have spent $55 million on a BRT in Scarborough if we weren't gonna bother with signal priority.
Till we find out a BRT would cost over $1 billion. Through it is disappointing, there is hope one day the city will prioritize transit while the LRT brings in more development on the Eglinton than a BRT would.
Signal priority is something that could be (relatively) easily added down the road, perhaps we can stop bickering?
The "bickering" must continue until we get proper transit priority. Otherwise the powers-that-be will forget about it.
^ Though it's worth mentioning that studies have found that BRT has induced as much development along corridors as LRT have.
I think a lot of recent posts are intentionally petulant, clearly it is a good thing that the surface section is connected with the underground section of the Crosstown. It is just that implementation is proving to be exceptionally disappointing especially given the errors are so obvious and preventable. The Crosstown is supposed to be the example of LRT done right.
