innsertnamehere
World on Yonge in Markham at Yonge and Steeles had 8 cranes at one point, from what I remember.
Not so much of a big pour here - it's just a standard 6 inch deep slab on grade for the most part - unlike say One Bloor East where they poured a 7 feet deep raft slab.
It's not a raft to float (so being near water is not a problem) it's one to make sure it's stable. If you are on solid bedrock you need far less man-made stability.Why the massive difference between here and Bloor? Wouldn't you need a larger raft here being so close to water?
Wow, through this whole boom I don't remember seeing a 3 crane project! Does anyone know what the last building that took 3 cranes to build in Toronto was? BCE place? Scotia? Richmond and bay stump?
Eau du Soleil is another one.Wow, through this whole boom I don't remember seeing a 3 crane project! Does anyone know what the last building that took 3 cranes to build in Toronto was? BCE place? Scotia? Richmond and bay stump?
Without getting into who's right regarding the raft, as I don't know, "subjective fact" is an oxymoron.That is simply your opinion sir, and that is your right. IMO the raft here is designed to float the structure. That is a subjective fact.
I'm pretty sure @buildup was just having a little fun there!Without getting into who's right regarding the raft, as I don't know, "subjective fact" is an oxymoron.
Yes, but it seems clear that they are down to solid bedrock and this would seem to be a good reason why they are primarily relying on it rather than building a large concrete raft. Your initial post raised the point about the site being near water and connected that to raft size but just because one is near the Lake does not mean that bedrock is not there.I meant more as a larger raft to settle in the less-firm ground. I'm not daft!![]()
Apologies, I'm not a geologist.Yes, but it seems clear that they are down to solid bedrock and this would seem to be a good reason why they are primarily relying on it rather than building a large concrete raft. Your initial post raised the point about the site being near water and connected that to raft size but just because one is near the Lake does not mean that bedrock is not there.
