Traynor
Senior Member
^Clumsy (the setback, not the photo.)
The same could be said of your rush to judgement. You are always too eager to sound the most well-informed and knowledgeable that you sacrifice scrutiny for speed.
Allow me to elucidate:
The clumsiness, to which I assume you refer, is the way the northern center section seems to step back from the facade in a double-step, awkward way (indicated below). When likely that secondary setback on the left (Which is the protrusion to accommodate the balconies.) will disappear in a few floors, as the balconies end and the curtainwall begins in that spot (Indicated in a close-up of a rendering I did recently. I am sure they will do a better job than my render.)
![BUH4M9P.jpg](http://i.imgur.com/BUH4M9P.jpg)
You will note that once the balconies on the eastern side of the north face end, the secondary setback vanishes and the curtainwall blends in nicely. Also, the addition of the service elevator hoarding, is adding a dimension of distraction from the smooth transition the curving curtainwall will make with the western half of the North face.
Certainly this is just speculation on my part at this point, however I will err on the side of caution before I judge the look of a finished project before it is even halfway completed.
