Amare
Senior Member
Just looking at all these proposals along the Golden Mile makes me think that the at-grade Crosstown LRT section is going to struggle immensely once all these developments come online. Wow
LRT will be fine here. It’s deceiving because there won’t be any density on the south side of the street (gotta protect those employment zones!) and the Ontario Line means a lot of people will transfer off before hitting the busier sections of the line closer to Yonge.
the overall number of people within walking distance of these stations will probably be surprisingly low considering the built form.
As has been previously mentioned, there will be density on the south side of Eglinton. Maybe not to the level of the north side, but the increased density will definitely be there. Also dont forget about "low-rise" apartments which are now being (in a lot of cases )illogically targeted for taller and denser builds.LRT will be fine here. It’s deceiving because there won’t be any density on the south side of the street (gotta protect those employment zones!) and the Ontario Line means a lot of people will transfer off before hitting the busier sections of the line closer to Yonge.
Can you link those transport studies? Interested in reading them. Just haven't seen any of the studies before.Transportation studies show different.
Also there will be density on the south side as far as the new O'Connor.
People are deluded if they think the south side with its employment designation is going to see significant employment growth. This is not an office market area whatsoever and I would be extremely surprised to see major employment intensification occur on the south side at all.
This area will be dense at full build out, but I suspect it will be able to be handled by the LRT. The density is deceiving as it's delivered in high rise towers, but it's mostly only on half the street, has little to no existing background population density, and even the developments themselves aren't actually that high density as they have large tower separation distances, significant park, road, and public realm elements, etc. which bring the overall density levels down.
thanks. So assuming 5 min frequencies and 2 car trains it’s slightly over capacity at full buildout, including the presumed large amounts of employment growth.See this post, by me, which has a link and excerpts.
Golden Mile Secondary Plan Study
In 20 years, can an area of the City developed so aggressively actually be a nice place to live?urbantoronto.ca
The key issue is whether the at-grade sections can be ramped up to tighter headways (sub 5 minutes) without ATC (which the surface section lacks) and maintain the reliable spacing required to effectively move passenger load; as well as how the surface section would handle 3-car trains.
Additionally, I'd have to go back through each of them, but the various Transportation Impact Studies for several of the developers in the Golden Mile show a red line on portions of the ECLRT indicative of over-capacity in 2041.
If you search one or more of those threads with myself as poster, I probably posted that graphic at least once (but can't be sure)
provided the ECLRT can implement 3 car trains, which it has been designed to do, it should be fine.
Those projections also include all the planned office growth on the south side of Eglinton which is unlikely to happen. It’ll likely be offset by higher than planned residential intensification numbers, but still.
