News   Dec 12, 2025
 518     0
News   Dec 12, 2025
 1.3K     5
News   Dec 12, 2025
 616     0
And Line 4 connecting to Pearson should capture a lot of employment trips at the airport, in addition to travelers. Line 5 will also connect to Pearson, but feeder routes from the north would be captured by Line 4 if it were extended and save a considerable amount of travel time.
Not only would it greatly improve access to Pearson from North York, Vaughan, and Richmond Hill, deep Scarborough would also get way better connectivity to the airport.
Even just building a straight shot guideway to Pearson and infilling stations as the Wilson/401 corridor densifies would be worth the money spent. Increasing ease of connection to Pearson should not be underrated as a source of economic growth in this city.
Line 4 could bypass the Pearson Transit Hub completely, and follow Rexdale Blvd./Derry Road, skirting the north side of Pearson, but connect at the Malton GO Station.
The airport is a pretty big detour for many people.
Walter, we know where you live. 😈
My gut feeling is that a direct connection to the Pearson terminals will give the subway more riders. So, probably would run the subway to the airport, and build a separate LRT on Derry-Rexdale, that connects both to the subway and to the GO line. Two separate lines might be more stable operationally, too.
Anyway, that decision is very far in the future, and would be subject to demand forecasts at the time.
I don't think anyone should wish for that. Going by early reports from the first concert it should be torn down asap and never be spoken of again.
I was at the first concert. The stadium is all temporary construction. No foundation. Clearly no plans for a permanent installation. As an indication of where the money lies, the washroom area is all portable toilets, while they did build a building for merch. The concessions, etc. are all tent-type construction. It was improved for Coldplay: the pathways to the subways and GO were not fully lit before. It was a bit hairy being in the dark with 10,000 others going the same way. People were basically well-behaved sardines.
If the goal is to cross the Humber River - that's a lot easier to do if the subway swings to Wilson than if it stays on Sheppard.
On Sheppard, west of the Weston Rd intersection, it will face Humber River, with houses on both sides. Will need to either demolish those houses, or go into a very deep tunnel under the houses and the river.
If the subway swings to Wilson, then it can cross the river on the bridge next to the 401 structures.
The question is where to swing. I believe, between Dufferin and Keele is the most logical option. Alternatively, it is possible to follow Sheppard till Jane, and then use the Hwy 400 corridor to swing south.
I suggest it continue to the airport. I put this on my blog
You could have Islington and Kipling instead of Rexdale, but the idea is an express subway line across Toronto to relieve the 401.
Yeaaaa no.
I would much rather see it terminate at Sheppard West for the time being. Once you get west of Bathurst, the density drops and regardless Sheppard terminates at Weston Road.
The real value is heading east where everything is built up and the demand is. Even at Morningside and Sheppard there is demand for a subway while the area around Meadowvale is being built out. Markham and Sheppard has been built up for decades.
Can we build it elevated though? That's the real question.
Bringing the line east will add more ridership, going east & west at the same time is the right thing to do for connectivity & new travel trip opportunities.
Why? Isn't the plan for it to be a subway which by definition is underground.
If there's existing subway in Toronto that's not underground, why does that preclude having more?
There's certainly elevated lines in New York City that are called subways. There's more London Underground that's not underground that there is underground. Along with a significant underground section of the London Overground.
And parts of the Chicago L that aren't elevated, and even in tunnels.
There's even a spot where the underground passes above the overground ;)
Although I don't know of any subway line anywhere that is 0% underground (the SRT would've sort-of counted if it weren't for a couple of short tunnel sections between Ellesmere & Midland, and if it were a subway rather than light metro).
I suggest it continue to the airport. I put this on my blogView attachment 668038
Doesn’t look very express to me, and Finch W is just to the north. Cutting SW to Wilson seems the more sensible routing even if it misses Woodbine, since there are at least two malls en route which could be developed as stations/TOD
