News   Dec 20, 2024
 1.2K     6
News   Dec 20, 2024
 898     2
News   Dec 20, 2024
 1.8K     0
I think most of what you say makes sense, but Gardiner east of Jarvis is low utility and a waste of money? You mean the section whose primary purpose is to connect to the DVP, a highway that feeds off into North York as well as the 401 and 404, serving a large chunk of North York, Northern Scarborough, and Eastern York Region? Also the highway is used by 401 East and 404 GO busses, and if the intercity busses move to Union, they will most likely use it as well.
Gardiner East is extremely useful and important, no less than any other section of the Gardiner. "Low Utility" is the last thing I'd describe it.
The bulk of traffic to/from the DVP uses the Richmond/Adelaide/Eastern ramp system.
Not true, especially for destinations on the western side of downtown.
about 20% of traffic on the Gardiner east is “through traffic” that doesn’t get on or off in the downtown, but downtown is a major destination so that makes sense.
the Gardiner rebuild program is about $2 billion from what I recall over 10 years, which is quite expensive but it includes the eastern Gardiner replacement, multiple interchange realignments, and localized widenings around the Humber River. It’s also about 30 years of capital work compressed into 10 due to decades of underinvestment so it looks worse than it is. After the 10 year program the highway will return to costing a few million a year.
MTO has a total capital budget for the entire provincial freeway network, including expansion, of about $4 billion a year from what I remember, about 75% on maintenance and 25% on expansion. It’s pennies compared to what is spent on transit, with GTA capital spends alone probably exceeding $10 billion a year right now.
MTO has a total capital budget for the entire provincial freeway network, including expansion, of about $2 billion a year from what I remember, about half on maintenance and half on expansion. It’s pennies compared to what is spent on transit.
@Northern Light isn't wrong, at least based on 2010 data:
Richmond ramp handled 40% of DVP southbound volume.
The Gardiner/DVP is basically a highway analogue of the YUS. Anyways, I think the Gardiner East (Phase 1 of the overall plan) is worth $300M.
Refer to p. 17.
18% of SB traffic on the DVP goes to the WB Gardiner in the AM Peak. (through traffic)
35% exits at one of DT off-ramps
40% exits at Richmond.
In PM peak, only 14% of traffic from Gardiner EB flows to the DVP.
That is statistically insignificant and easily absorbable by LSB.
Total traffic levels would require an 8-10 lane LSB - I’d much prefer a 4 lane elevated Gardiner with a much smaller LSB for a pedestrian standpoint. LSB right now in the eastern Gardiner area is far too large for what it needs to be, it could easily be downgraded to a 4 lane arterial.
Indeed. I get the general push to reduce auto traffic in the densely populated areas, but then the best option seems to be tolling the roads and thus reducing the number of cars entering the area.
If the solution is to accommodate nearly all existing traffic, just using a boulevard instead of the elevated guideway .. then I don't see how a 8-lane road is greener, or a lesser barrier, than the highway it replaces.
Frankly I personally think wide boulevards are worse than elevated viaducts. You can pedestrianize the area under a viaduct. Tbh, when you only factor in crossing the respective corridors, I personally find crossing the Union Station rail corridor to be a lot worse than the Gardiner. With the Gardiner all you have to do is cross a dark 3 lane road. Its not the most pleasant experience but its like a needle, you just cross the street and its over quickly. With the Union Station corridor, you walk through a long tunnel for like 1-2 minutes, and the repetitiveness makes the tunnel feel even longer than that. Frankly I'd argue that the worst part about the Gardiner isn't the Gardiner, but LSB underneath. Hypothetically if we got rid of LSB, and turned the area under the Gardiner into a linear park, while it won't be the nicest place in town it would be perfectly fine as a pedestrian, just maybe a bit loud but even then there are ways to mitigate noise such as sound barriers.
Part of it is psychological - say if you were to replace the existing University Avenue with an elevated structure along the lines of the Gardiner, one would still perceive it to be a greater barrier. The wider the structure, the worse the effect. Traffic impact aside, there is a reason why elevated expressways are often target for removal (and it isn't a North America only phenomenon) - simply because they just tend to be sucky for the urban experience.
And no one even try and bring up Bentway as a rebuttal - it is the highest/most elevated, most open stretch of the Gardiner - nothing like the rest of the expressway through the core, which is claustrophobic and hemmed in.
Now if I get to choose, I'd say maybe a 5-6 lane elevated replacement for the Gardiner East built to modern standards (single central supporting column) along with a realigned LSB would be a balance. But that's more expensive than the repair option.
Visually, elevated is the worst. But for the actual mobility, elevated might be a lesser hurdle, dependent on how it is built.
If you had a chance to see the new "greened" Hwy 7 in Vaughan .. 6 general lanes in each direction, plus 2 median BRT lanes, plus left turn lanes, and at some intersections, right-turn lanes as well, and as the icing on the cake, 2 bike lanes. They tried to make everyone happy, but ended up with a monstrous canyon that requires a cab ride just to cross from one side to the other.
EDIT: 6 general lanes in total (3 + 3), not in each direction; I mis-spoken. But still, one needs to pack a snack before starting to cross.
If you ignore the flurry of negative articles that came out since the start of this service, then sure. Whatever.
That's true. There was a lot of criticism, not about the concept but regarding the fact that it is overpriced and built with no easy way to expand the capacity.
That's why I think a relatively narrow elevated expressway designed for through traffic, pushed as far north as possible, combined with a reasonably redesigned LSB is the best solution for Gardiner East if the goal is to retain the connection while maximizing the quality of the urban realm. Too late for that now, it will be what it is for the next 30 years or so.
is that not what is happening?
