Dan416
Senior Member
Highway 7's jog in York Region, as Former Highway 7 jogs from being Queen Street east of the 410 to being Bovaird west of the 410. Looking at the map the northerly concession for both is close, but not the same.
Technically this applies to many provincial highways. Roads were designated provincial highways with the Department of Highways (now MTO) rebuilding the road to higher standards and eventually eliminating jogs and building bypasses. Ultimately those bypassed sections are decommissioned. I believe there isn't that many conventional highways that were built from scratch for their entire length or even significant portions. There isn't that many at-grade expressways in Ontario. Of course most the freeways were paved over farms more most of the length.Highway 7 used to jog at Yonge Street (Highway 11). It followed the first east-west sideroad north of Steeles Avenue (connecting Brampton, Woodbridge, and Thornhill), then continued along the second east-west sideroad north of Steeles Avenue to connect with Unionville, Markham, Brougham, and Brooklin. For a few decades, Yonge Street carried both Highways 7 and 11 for a short bit. The original route of Highway 7 jogs a lot between Sarnia and Ottawa, connecting towns and cities together along mostly existing concession roads and sideroads. The route straightened out a bit by way of re-routings and bypasses, like the one between Concord and Yonge Street which by-passed Thornhill, partially on a new alignment, partially via Langstaff Road.
The old route, Centre Street, was designated Highway 7B for a short period.
Lowering tolls will result in more cars (obviously), but it will increase maintenance costs right? Since more cars use the highway, then the more damage and wear and tear is applied to the road. Is that one of the reasons the 407 ETR company has such high tolls? Is the "balance" they have correct, or is there a balance to be found that results in the same amount of "profit" for the corporation and a better experience for drivers?
The trouble with turning what was once a regional arterial connecting communities across Ontario into an urbanized Main road is dealing with all the through traffic travelling between those communities that will now be slowed by the now urban built form. 407 accomplishes part of this but is hindered by it's tolls. If you want to turn "Hwy 7" into an "Avenue 7" (to steal some municipal marketing speak) you need to provide a bypass around the built up centre.
From what I've seen on Google Maps, Highway 7 in Markham used to be named Wellington Street. There's currently a short disjointed section west of Markham Road named "Old Wellington Street".Didn't Highway 7 have a historical name in York Region?
I'm guessing it made sense to call the whole thing "Highway 7" rather than the old names for the local sections in each municipality. Compared to Brampton, where the road is disjointed, with a short stretch down Main Street, I'm guessing that it didn't make sense to call the separate disjointed roads all as Highway 7.
I think it's because Highway 7 in York Region was stitched together in the mid 1980's to create an almost-expressway-expressway, uniting what was Centre Street in Vaughan, the short stretch up Dufferin Street, and parts of Langstaff Road in Richmond Hill.
If the Gardiner was removed, likely the new Lakeshore would look like highway 7. Now that Gardiner and 7 are as is, development must account for it.The Highway 7 at-grade expressway was only built cause they have to make room for 407 along with a new alignment bypassing Centre and Yonge. Early plans only called for the 407 to be built in phases with the 427 to the curve just north of Centre to be built first. Then all the changed with the NDP creating a toll to finance the highway for 35 years for more of the 407 to be built at the same time. Otherwise I don't think the Richmond Hill part of Highway 7 would look like what it does today if it wasn't for the 407.
In Markham Highway 7 was just built by connecting a bunch of disjointed roads, which is why there are the slight turns at McCowan, Markham Road and Ninth Line.
