TKTKTK
Senior Member
Ah, back in this thread, going back-and-forth with TKTKTK. Feels like old times.![]()
*sigh*
It's an ugly underpass at this point, sure, but given that it's not all that wide I think there's a lot that could be done to make it more hospitable. There are underpasses of similar length all over the city and no one sees them as barriers.
For example?
I'm trying to think of an underpass as long, low, dark, and dank as these. Hell, we have sewers that are larger and more welcoming.
The Memorial Park Storage Chambers in Toronto's Belt Line Drain
(Of course, your counter-argument might be: Why don't we just beautify the underside of the Gardiner? To which I'll say this: Right now, we have the railroad tracks, the Gardiner and the Lake Shore, all of which are ugly and serve as barriers. Getting rid of the highway, improving the streetscape of the Lakeshore, and beautifying the underpass is the best workable solution in this section.)
Well, the best workable solution would be to improve the streetscape (far easier when you can push traffic volumes up out of the way) and beautify both the Gardiner and the Rail underpasses. But for some reason you want to reject that clear logic.
Of course, having said that, my support for this plan hinges almost exclusively on the Lake Shore proposal. If they're just going to cheap out and give us an at-grade highway with stop lights at every intersection, then why bother with this at all?
You honestly, honestly, honestly, believe it will turn out any differently than the above? Honestly? It's what they describe!
If you accept the lowest numbers for added trip length (what, 2 minutes?) then you also have to accept similar road speeds to what we have now, which is not appreciably slower than the Gardiner above.
If you want to accept slower speeds and a more pedestrian friendly environment, then you have to reject that 2 minute number and settle quite a bit higher (as it stands right now, each of the traffic-light cycles on Lake Shore are like 3-stages and 2 minutes long on their own! and good luck hitting all the greens)
