Open up lakeshore pedestrian barrier
Nov. 27, 2006. 01:00 AM
Living beside the Gardiner
Nov. 26.
The best solution to downtown waterfront access is to eliminate the pedestrian barrier created by Lake Shore Blvd. It's way too late to eliminate the visual barrier created by the Gardiner Expressway and the thousands of condo units between the commercial core and the water. Development beneath the Gardiner is not a new suggestion, but it's obviously the best one.
Pedestrian-friendly enclosed commercial and public spaces built from the ground right to the underside of the Gardiner, from the CNE grounds all the way east, is the most practical connection between the core and the waterfront.
I'd go even further with the radical proposal to double-deck the Gardiner, with express-only on a new upper deck from the CNE to the foot of the DVP. With that traffic relief to the existing Gardiner and some adjusted on/off ramps for the downtown core, we entirely avoid the new pedestrian barrier created by the Waterfront Revitalization Corporation's proposed 10-lane surface traffic solution after a Gardiner teardown.
Traffic flows and Gardiner vehicle capacity would be vastly improved and separation of through traffic from on/off traffic is obviously desirable
Development of the hundreds of "new" downtown acres now occupied by Lake Shore Blvd. would provide enormous revenue and fund the project, and then some.
Protection of the underside of the Gardiner by the new structure below it would reduce maintenance costs and allow the demolition of many of the ugly concrete supports now used to hold the Gardiner in the air. Cut-and-cover tunnels for north-south streets could connect to tens of thousands of new underground parking spaces and Gardiner on-ramps.
Most importantly, the new structures provide a wonderful opportunity to plan entirely new gateways to the waterfront with pedestrian throughways integrated with indoor parks, restaurants and stores. Connections to the PATH and facilities such as the Air Canada Centre, the Convention Centre, the Rogers Centre and the CN Tower are obvious. Connections to the revitalized waterfront are unconstrained.
Selective building above the double-decked Gardiner, with 12 lanes of traffic on two levels sandwiched between the lower and upper floors of a taller building should also be considered.
There is a chronic failure of imagination in Toronto, coupled with the Canadian malady of thinking small."
