News   Apr 13, 2026
 275     0
News   Apr 13, 2026
 293     1
News   Apr 10, 2026
 1K     0
Parking - Catch All
Inflationary adjustment in 2026? I thought the 2026 TPA budget was approved with a parking rate freeze. Is this referring to the 2026 prep of the 2027 budget?
2026; they're looking to push the rates higher. (Yay!)
"Modified rates" is interesting. There is the most to gain not from moving every rate up by the same amount but actually moving high demand areas into higher tiers.
Agreed, and this could be part of that, there are other modifications possible as well.
As I noted above, rate hikes are coming to on-street parking via a report to next week's TPA meeting.
Of note, the majority of the increases are small, only .25c per hour, which I expect is the result of the requirement to 'consult' ward councillors on parking rates, something that should be removed.
However, that same policy results in one glaring (and positive) anomaly. Councillor Saxe clearly pushed for higher parking rates in her ward and as a result, rates are rising by $1.25 or more at select locations, with some spaces jumping a whopping $2.75 per hour! (great)
Primarily along Bloor and throughout the U of T campus. Good for her (seriously)!
Here are the rate changes:
To see the full block by block rate structure, follow the link below:
I’m good with higher rates but I don’t like the flat rates on weekend for some private lots when you need just a quick stop.
Last year the big change was that almost everything south of Carlton/College between Spadina and Jarvis was moved into tier 1 which at the time was $6.75 an hour. The big change this year is the north half of Downtown, Carlton/College to Davenport from Spadina to Jarvis is now moving to tier 1 which has been raised to $7 an hour. Streets like Yorkville, Scollard, Cumberland, Charles, St. George, St. Mary, Bloor, Hoskin, Harbord, Wellesley going from $5.50 to $7. Many of these were just $3 an hour until the 2024 rate increase. That's a huge jump. It was stupid that street parking used to cost half of going in a garage. Will be very interesting to see if this makes people start thinking twice.
On a related note the east/west drop-off is still too steep. At Spadina and Jarvis rates drop off form $7 an hour to $4.50 an hour. I expect people will figure this out.
@Northern Light @nfitz
They used to have two exits but both doors are locked. 2nd floor SE and NW corner.
The 2nd floor parking lot store entrance has been closed since the early days of Covid.
It appears they were renting the upper parking space for day time construction and maybe the summer 🏝️and the 🧑‍🎄 parade crowd. Use at your own risk but I guess the chances of a getting stuck up there in an emergency with the ramp blocked are slim to zero.
I’m surprised they sunk a ton of cash into the EV charging network on the ground floor. Will they recover a million dollars in profit from their EV customers over the next few years before they re-work this property.
10 Lower Jarvis (Queens Quay Loblaws) still spending money fixing up the parking lot
...and Loblaws / CHOICE will continue to do so until such a time as the Waterfront East LRT is funded and under ctive construction.
In Europe, they use pay-for parking, ALONG with bottle, can, and beverage container refund returns. You can pay for parking using the return on containers. The small-c conservatives is way behind the times.
