So because they are rushing work on Sheppard and doing construction before design is finished (generally leads to higher costs), they should do the same with Eglinton?
No, that's not what I said. Starting construction before design work is finished is not the most responsible thing to do, and starting it before even the mode has been written in government stone would be still less responsible and force design's hand. Eglinton is a completely clean slate that officials are mercifully taking a more cautious approach to than was the case on Sheppard. A few years of bickering about Eglinton would be desirable if it did something like take the ICTS spectre off the table or if it means increased grade-separation (and such possibilities would very much affect the design and prevent sections of the line from being rushed ahead), but we'll see what actually gets built. The road/rail separation at Agincourt is something that would have been built eventually, anyway, no matter what transit was built along Sheppard, but by getting it rolling before the rest of the corridor is figured out, they can point to it and say "Well, construction has started, you can't change or cancel the Sheppard LRT now!"
If there was some kind of existing transit line on Eglinton that was potentially going to be altered or extended, there'd be different pressures put on the design and construction and phasing of an Eglinton line, and then, perhaps, we'd already be seeing soil moved back and forth to show off how 'construction has already started.' But there is no existing transit line on Eglinton, the LRT is not being designed with spite in mind (unlike Sheppard), the corridor is being singled out as Important with Regional Consequences, and the pricetag is exploding, which all changes the motivation behind any stalling or delaying tactics that may have been taken.
Transit City is a Toronto wish list. MoveOntario is an Ontario mandate. There is a world of difference in between them.
The difference is that MoveOntario is a mandate to build Toronto's wishlist (and other regional projects). Everyone knows this.
That's a good question .... but if you admit that the posts are nothing more than mindless contrarian twaddle, why do you persist in making them?
Wow, you're so clever! Or, your so clever, to use your preferred misspelling.
