News   Apr 16, 2026
 393     0
News   Apr 16, 2026
 1K     1
I don't think 80 - 90 km/h average speed is feasible with the amount of stops we have on the GO lines.
I'll go back to my JR line example: it takes 57min to travel 53km, making 13 stops (an express run). Average speed would be 56km/h. They are using EMUs.
Chuo line timetable - Chuo S-Rapid
You can sort of estimate how fast the trains would have to run and/or how many stops to eliminate, in order to achieve 80-90km/h average...
If GO can cover Barrie to Union in less than one hour, that gives it an average speed of about 100 km/hr. That sounds unrealistic even for an express service. I remember long back seeing the new proposed times for every route in this thread. It will be great to get our hands on that again.
Also, I read that time savings will be up to 20 to 30 minutes per Metrolinx (average time saving is lower than that). Having Barrie-Union done in less an hour means 40+ min saved which contradicts Metrolinx's statement
Managed to find the full business case with the proposed times on the Metrolinx website: Go Expansion Full Business Case. Barrie line times are page 90 of the PDF/55 of the document.
I wouldn't put much stock in the numbers though. For example the Barrie line has 81 mins from Allandale to Union on peak, and 59 mins off peak. I tried to figure out how they came up with such a different number when the proposed service pattern is almost the same. Sure there's less dwell time off peak, but not THAT much. Until I looked at the section above and saw electric loco service - up to 8% faster, EMU up to 29% faster. The plan proposed using electric locos from Barrie on peak, but EMUs off peak, so that seems to be how they calculated such different times. Except most of the time savings is shown between Bradford and Barrie South - one of the longer stretches between stations where the acceleration difference of an EMU vs loco hauled would make the least difference. So I have to assume these numbers were just calculated quickly and without much attention to detail.
Or (to be a bit kinder) the numbers were accurate and well developed for the equipment and service plan and station locations and track parameters as they were spec’d at the time the BCA was prepared…. but so many details have changed since then that those original calculations are no longer applicable.
Variables don’t, constants aren’t.
- Paul.
And how much experience does DB have with operating in North America?
I wouldn't expect too much of them, especially at the start. They are going to have a very steep learning curve.
I believe Deutsche Bahn's International Operations first passenger rail contract is GO RER, though they recently won a contract in India which will begin operations this year. They also have a freight contact in Uruguay starting this year.
I think everything else DB operates uses, at least partially, German infrastructure. In short, their Operations branch is very new to anything outside Western Europe.
Their Engineering and Consulting branch has done quite a bit of work outside Germany, but not operations and Alstom has the engineering role for GO.
Will DB have some unique interactions with NA ops and practice? Yes, but most of the trackage where we will be operating frequent service is owned by MX with freight as the guest, I think it's very concerning to suggest that they should not be aiming to operate in a non-North American way, thats why we are installing ETCS and other infra that is used in Europe. DB has worked on other stuff in NA too. There is of course a learning curve, but I would guess thats why there are so many years of planning between the consortium and MX before implementation. Basically, they aren't going to be operating on a typical North American railway, I mean GO is already unlike most operations on the continent!
Of course we are hiring DB so that they can operate trains their way, of course they will need to accomodate for truly necessarily North American things like loading gauge - and mixed traffic where it exists, but a lot of stuff we do is not set in stone. Even if all they do is propose improvements to the way we do things today as opposed to a paradigm shift. And yes, these things are compatible, Australia and Mex come to mind as places where both ETCS and a lot of Euro derived infra is mixed with heavy NA style freight.
Edit: TBC this isn't really meant to be pointed at either of you, just a broader sense I worry about that we will bring DB in to just do things how we do them today. A ton of the projects we are doing and have done in the past on the GO network are to enable more isolation from the trad mainline rail network so that we can operate stuff differently.
^Clearly, getting headways down under 30 minutes - 15 would be ideal - is critical. Hourly is acceptable for longer distances where even with a wait, the overall transit time is competitive to driving.
To my mind the limiting factor for regional service is the poor quality of first mile/last mile rather than the speed or frequency of the backbone rail service. We can’t rely on parking garages at stations to handle all the potential ridership. The whole playing field needs to be adjusted - municipalities are not well aligned to deliver people to GO, and for the majority of the suburban area we are not going to attract ridership door to door by running 40-foot buses deep into suburban neighbourhoods. Nor are municipalities likely to fund or apply innovation to their local transit operations to achieve this, even though there may be mutual benefit. We need a new “pact”, and Ontario may need to pony up the starting investment and perhaps financial incentives to riders and to municipalities to get things going.
TTC attracts oodles of ridership with a good suburban last mile bus service, and a lot of the 905 has this service - it just needs beefing up and expanding to connect with trains that don't just run during rush hour.
I would like to be proven wrong, but let's perhaps temper our expectations for DB. They seem to do well enough in Germany, but I suspect GO Expansion will be delivered by a subsidiary of the company like Arriva. And the thought of anything like Arriva coming to take over GO should be adequate cause for panic. Their lack of vision, service planning has given a handful of bus operators in the former Czechoslovakia no end of difficulties.
It's not Arriva. This is a very different project - they are involved deeply in infra and planning, not just operating existing trains on existing infrastructure.
I think simply increasing service to All day 2 way on several corridors will increase ridership substantially ( Theres a whole Facebook car pooling world which could be made obsolete), In cities like Kitchener, Hamilton or Barrie, there is probably more off-peak travel to Toronto than on-peak.
As someone who lives and works in Barrie, absolutely. More off-peak train service here would make the city feel less isolated from Toronto and everything it has to offer on the weekends.
Strangely, Lisgar GO has no weekend bus service, much like Dixie GO.
There are direct-ish local bus options or GO bus stops to them, or at least to neighbourhoods adjacent to them. But the only way between Guelph and Kitchener-Waterloo is the long way via the 401, with a transfer at Aberfoyle. Apples to oranges, IMO.
You probably know who I am and that I am very much aware of what connects to what and what doesn’t connect. I was just pointing out of one the other strange things GO buses do.
Totally, and I hope you know I'm never taking a shot with these comments, it's just laying it out for everyone reading on the sidelines, and continue the discussion (and really emphasize "WTF GO, C'MON!").
Agreed. The only comparable North American commuter-rail system to GO-RER is the Long Island RailRoad, which also has very unique operating characteristics that don't really work for Toronto.
Either way you go it's new territory for the hired operator (either the service levels or the regulations). Alstom is the closest entity to having experience with both, and they're very involved with setting up the physical infrastructure.
DB's biggest issue will be training and retaining engineers for the level of projected service, something Bombardier was not able to adequately resolve either.
I read the Alstom job document for April 9th and beyond today, and from what I read the Stouffville and Barrie Lines will have a major service decrease on the weekend for the foreseeable future. Though I’m not sure if these plans are 100% finalised yet so I’ll have another look in a couple weeks with revisions will be released.
A GO bus has now been spotted for at least the second time on Woodlawn Road (Highway 7) in Guelph, from Kitchener. Steven thinks it's testing a new direct route, I really hope he's right.
This is a long time coming and will be really helpful for off peak service.
Fingers crossed the next service announcement is a GO Guelph - Kitchener Bus and weekend train service (that includes service to London)
