CN has lost a major customer on the Fergus Spur. As a result, the job which services the line is no longer based in Cambridge. Abandonment is likely around the corner which means that GO service to Cambridge by this route is likely off the menu.
IMO, extending the Milton line has always been the better option as busses would likely be better suited to Cambridge - Guelph journies and connections with the Kitchener Line.
Reactions: rbt
Interesting news, but I don't understand your conclusion.
Surely CN abandoning the Fergus spur makes the Guelph to Cambridge routing more attractive to Metrolinx, not less. Metrolinx would have fewer conflicts (CN operations) to GO service on that corridor, and potentially lower capital costs too.
Operational conflicts with freight are not really a concern with this project. The problem comes from the fact that since Cambridge GO service is not an immediate priority, neither Metrolinx or the region of Waterloo are likely to purchase the RoW leading to it being redeveloped in pieces.
This is amazing - GO's bus services are usually a massive pain to understand because of all the separate timetable documents for each route.
What's worse, it's not even easy to know which timetables to check because the official system map is completely useless for looking for GO bus routes, so you basically just have to open lots of timetables and look at the route maps to even check if the route is useful to you. I think most GO bus riders probably just blindly follow Google maps or whatever and have a next to no understanding of where any routes actually go apart from the routes they regularly use. Most riders of other systems probably at least have a vague idea of where service goes.
Thanks!
The challenge with mapping GO's bus routes is that they're so variable. In my timetables you can see that the service patterns vary quite significantly over the day. Route 45 only runs in the morning and afternoon, meanwhile routes 47G and 47D only run in the afternoon and evening. This variation is very useful as it allows GO to closely match service patterns to travel patterns.
Inevitably, many of the service customizations make the routes less intuitive. For example, a few years ago they started through-running many of the 407 East and 407 West bus routes. This is definitely an improvement for passengers, since it cuts down transfers, but it made the timetables a mess. Instead of one 407 East timetable and two for 407 West (route 40 always had its own timetable for some reason), there are now 3 for 407 west and 2 for 407 East.
However, there are certainly some improvements GO could do to service legibility, without actually changing the routes. For example, Routes 56 and 41/47 are shown on different timetables (tables 54 and 41 respectively) despite effectively being branches of the same route. During the midday, the two routes are blended to provide a 15-minute service from Oakville Park & Ride to Richmond Hill Centre via Square One, Bramalea and Hwy 407 Station.
They should include route 56 in table 41 so people can actually see the regular 15-minute service in one place.
Meanwhile route 48 should be removed from table 41 and given its own timetable since it has only shares the corridor for a single stop (Bramalea - 407 Stn) and adds it a lot of unnecessary clutter.
They also could rationalize route numbers and letters. Services which pimarily follow the same route should have the same number, and routes which have little in common should have different numbers. Route 21 could probably use a second route number to help cut down on the alphabet soup. For example, most of the services to Square One and Lisgar are independent from the services to Meadowvale and Milton.
Meanwhile routes 41 and 47 are actually the same route - route 47 is just a short turn branch. They could instead be 41 and 41B for example.
They could also use some rationalisation of branch letters. It could be useful to have some trends in letter choices, similar to how the TTC used to reserve the letters E and F for express branches. This would help make branch letters easier to remember. For example 25C could have been 25E.
They should also eliminate redundant letters, like the TTC has done. Branches which merge together and run to a common terminus don't need different branch numbers, since nobody boarding the bus needs to distinguish between them. For example westbound routes 41 and 47 could both just be "41".
Does anyone know of any unofficial maps that exist that actually depict all GO bus routes? Such a map really needs to exist.
I did try making some service maps a few years ago: Here is a map of the weekend service from 2017:
I made the map specifically for the weekend service because the service patterns are simpler and more consistent than on weekdays. On weekdays you'd need a map for early mornings, then a different one one for the AM Peak, another one for early midday, another one for late midday, one for PM Peak, one for early evening, and one for late evening/overnight.
The legal process for abandonment requires CN to offer the line up to other users as a shortline railway. Considering that both the City of Guelph and the Region of Waterloo already own such branch lines and are familiar with the process, I’m optimistic that they might step up, as much to protect future industrial development as for GO’s use. #thankfullythisisn’tOrangeville
The loss of business is the big story - any intel on what happened to the traffic? Is the customer switching to trucks? Is there a transload somewhere? How hard did CN fight to retain the traffic?
Not a lot of intel on what happened. The customer they lost as a logistics company. A transload which handled drywall.
In my view, CN was likely demarketing this line. In general, their takeover of the former GEXR territory has been a disaster with substantial traffic losses.
I'm not as optimistic that either Guelph or the region will step in as Cambridge GO service isn't seen as a priority right now and has other, more optimal routings available.
In general, the damage has already been done by shifting freight to road and causing an industrial area to lose access to rail.
Actually the region is very interested. It has spent hundreds of thousands of dollars on studies for Cambridge go. The problem is that the Region is in a money crunch and does not even have the money to build Kitchener central Station. This is ML's chance to step in with the $$.
Side note - it often feels like Metrolinx has contempt for the Region of Waterloo. Like on the weekends its a multi transfer three hour trip to Toronto even though it could be 1.5 hours. Destinations that people want to go to ex Guelph and Hamilton are not served . Even though most prominent folks in Waterloo want more services ML fails to actually plan these service expansions
They are interested, but your comment proves my point. They likely won't have the resources to buy out the line when the time comes as the salvage value will likely be inflated as what tends to happen when these lines go up for abandonment.
Similarly, Metrolinx will not see it as a priority as what was done with the OBRY.
I know someone linked an old version of my map earlier but I have an updated version. I think I got everything but I might have some errors due to the complexity of the network.
  • Jan 2023 Ontario Regional Transit.pdf
GO bus (and GO in general) needs a major wayfinding rethink - the system is not really easily understandable right now. The process of getting schedules, the way the schedules are designed - I seriously think a summer intern in UX / Design could create something significantly better. The experience also is not much better at stations and stops.
They also really need to rectify the SINGLE Presto reader at the front of GO buses - it makes loading and unloading comical.
Here, I agree with you 100 percent. The presto machines, a lot malfunctioning wether its GO or TTC or MiWay or Durham or Hamilton etc
Here is my annual Canadian Commuter Rail Summary:
https://ontariotrafficman.wordpress.com/2022/12/30/canadian-commuter-rail-summary-2022/
Since the lockdowns have ended, ridership has been steadily returning to Canadian commuter rail lines. But the service levels have not kept pace.
At the start of January 2022, train schedules were nearly at their pre-pandemic levels, but in practice service was much lower due to chronic operator shortages. In Ontario, many trips were cancelled on a regular basis because there wasn’t anyone to operate them. So on the 10th of January, GO implemented drastic service cuts to schedule a service they could actually operate.
The service cuts were nearly as severe as the original service cuts from March 2020. Peak-period service was reduced to half-hourly on the Milton, Kitchener, Stouffville and Barrie lines, and to hourly on the Richmond Hill line. Weekend train service on the Barrie and Stouffville lines was cancelled altogether and replaced with buses. All express trains (on the Kitchener and Lakeshore West lines) were cancelled. And counter-peak service was also cancelled on the Kitchener line. On the Lakeshore lines, off-peak service was cut to half-hourly in the midday, and hourly on evenings and weekends.
At the time, I expected service would start returning to normal within a few months when the wave of operator illnesses passed. But service returned much slower than expected.
In April, half-hourly evening and weekend service was restored on the Lakeshore lines, and weekend service was restored on the Barrie and Stouffville lines.
At the end of the summer tourist season, the number of round trips to Niagara Falls was reduced from 3 to 2, which is a far cry from the 4 round trips which were provided year-round prior to the pandemic.
It wasn’t until December that weekday schedules started to return to normal, with peak period express services restored, and local trains added to increase frequency during the peak hour.
This year’s charts compare the January 2023 service to the service scheduled in December 2021, just prior to the drastic cuts of January 2022.
Frequency
Although service levels have almost returned to normal, there are still some notable deficiencies compared to the Fall 2021 schedule.
The only frequency improvement this year is that 15-minute service was restored on the UP Express, though only during the peak periods. This still falls short of the all-day 15-minute service prior to the pandemic.
On the Lakeshore lines, midday service continues to be every 30 minutes, instead of every 15 minutes. Evening service on the Lakeshore West line is also limited to every 60 minutes due to construction on the Hurontario LRT at Port Credit Station.
The Kitchener line finally regained some counter-peak service to Bramalea in December, but there are still some 90 minute gaps in service.
Peak period frequencies on the Barrie, Milton and Richmond Hill line are also lower than normal. Hopefully additional trips will be continue to be added as new operators begin service.
There were no changes in frequency outside of Ontario.
Speed
With increased ridership come longer dwell times at stations. As a result, many lines had one or two minutes added to their schedules.
But not the Kitchener line. Thanks to Metrolinx’s railway upgrade project between Kitchener and Georgetown, this year’s Kitchener express train is the fastest it’s ever been. In fact, with an average speed of 65 km/h end-to-end, it is the fastest Canadian commuter service ever included in these annual summaries.
While Metrolinx has been upgrading the Toronto-Kitchener railway, CN has allowed the the Kitchener-London railway to continue to deteriorate. Nearly the entire line is affected by speed restrictions due to track quality issues. Only a few segments between Kitchener and Stratford allow trains to reach the 60 mph (96 km/h) line speed, which itself is already lower than the 70 mph (112 km/h) speed limit which was in place until 1996. Trains now take a whopping 2h15 to cover just 90 km from Kitchener to London, which is an hour longer than that trip took in the 1970’s, stopping at the same two stations along the way.
The Mascouche Line somehow managed to get even slower, now taking nearly two hours to get from Mascouche to Montreal, which according to Google Maps is only 15 minutes faster than riding a bicycle. Next year travel times should improve as trains will terminate at the new Côte-de-Liesse REM station where people can transfer to REM line which has taken over the former route of the Mascouche Line through the tunnel Mont-Royal.
