News   Apr 02, 2026
 2.3K     3
News   Apr 02, 2026
 1K     0
News   Apr 02, 2026
 2.6K     2
Anyone know if there is any particular operational reason Go is using a double header consist for the London trains, (locomotive 558 and 561 to be exact)
Protection. The train now operates so far away from GO's core network that there is a legitimate concern that should the train crap out that it would take several hours to source the buses to rescue the passengers. A second locomotive added to the consist should ensure that only in the most extreme of cases would a train not make it to its destination.
On top of that, Metrolinx has retained the services of two small Southwestern Ontario bus lines to provide buses on an emergency basis should the need arise, but their primary plans still call for the use of their own equipment and staff.
According to recent Google Maps imagery there isn’t a switch from the track that serves the furthest west platform to the Milton Line track(s). I’m not sure how Milton Line trains could serve Bloor GO? Was one installed recently?
One has not been installed, nor are there plans for that to ever happen.
There are no plans to have platforms built for the Milton line tracks at Bloor, either.
That would be a similar reasoning as for why VIA always has two units on its Winnipeg-Churchill service, since the lack of road coverage would only leave helicopters for evacuation...
Maybe it's to aid on-time performance through better acceleration? You would be surprised how much travel time represents the difference between once loco and six cars (which has the same power-to-weight ratio as 2 locos+12 cars) and the same loco with twelve cars...
There is no such connection between the Galt Sub and any platform track at Bloor, to the best of my knowledge...
Your right.
As I was working on some photos last night I realizes that the switch is for the 2nd Milton tracks (5 & 6) and no connection to Track 4 for the Bloor station. The other thing I should have caught what the next 2 stations were as they are on the KW line, not Milton
As well most classes don't go past 6 pm so the train back makes sense for Friday night.
Unless it's changed since I was a student, classes end at 4:30 - other than the dreaded 6 pm to 9 pm evening spot - but I only ever had a couple of those over the years there.
Gosh, does that mean VIA had to barge out TWO locomotives after the flooding and suspension of the line, with a train trapped in Churchill? Talk about bad luck ...
I was on the Algoma Central train heading back south from Hearst in 2014. The locomotive had a serious problem. Luckily, we were just approaching Oba, so we had a general CN freight locomotive stationed at the yard there to haul our disabled train the rest of the way back to Sault Ste. Marie.
So I guess at that time CN operated both trains? So you didn't need a new crew to take you home?
CN owned and operated the ACR since the mid 2000s. The slow ride into Oba and the switch of locomotives added time - a new relief crew met the train at Searchmont, so we were pretty late getting back into the Soo.
Why are there no plans for having Milton trains stop at Bloor station? Is it because that line already stops at Kipling station and anyone that wants to use subway can get off at Kipling?
Yes. The subway takes only marginally longer than the GO train between Kipling and Dundas West. The subway is slower but also more direct. So with such a minor benefit it wouldn't be worth the considerable cost of widening the corridor to fit a third island platform, nor would it be worth the capacity/reliability impacts of an at-grade manoeuvre to the existing platforms.
For a long time, GO has felt that only a single subway connection on each line was sufficient. And with the connection at Kipling, another one at Bloor wasn't required in their mind.
Now, however, there simply isn't enough room to allow for platforms on the Milton Line.
Apparently 11 people got off at Stratford last night so it seems to be a slight improvement in ridership.
To be honest I can see Stratford getting more use out of it than London. For them having significantly another means of accessing Kitchener, Guelph and beyond is undeniably a net positive. Plus maybe if they need to I wonder if they could maybe fit in a new yard in Stratford
Can Milton line trains potentially switch tracks to share platforms with the Kitchener line at Bloor?
