News   Apr 16, 2026
 236     0
News   Apr 16, 2026
 717     0
News   Apr 16, 2026
 1.1K     10
Will Metrolinx rename the line to the London Line, now? Lakeshore East and West being the exception, they seem to name the line after the last town/city on the line.
If I had to guess I'd predict they will rename, but given the travel patterns involved I'd prefer sticking with the Kitchener branding.
It will be interesting to see what the schedule is as that would make it clearer whether Metrolinx is targeting commuters into Toronto, or people traveling on points along the line.
My gut is that this is tied some way into the endless promises for improved rail service on the corridor. An incremental approach to improving a line is certainly easier to sell politically than an ambitious and expensive HSR plan.
Considering this is just a pilot they’ll likely stick with Kitchener for now. I imagine if/when they purchase the rest of the Guelph subdivision they’ll rename it to the London Line
Remember the federal announcements?
My gut feeling is that using London is too far out for commuter travelers in the GTA. "London Line" doesn't really tell you where it's going, unlike "Richmond Hill Line" or even "Kitchener Line."
Or the "Kitchener-London Line" or "Western Line."
And here i thought thinking 4 hours on the Toronto-Sarnia Via rail trip was bad…
I feel like this London extension is probably the best for Kitchener or Guelph riders, decent for Georgetown/Acton and maybe even as far as Mount Pleasant as a stretch. Brampton and Toronto is too long so it’s probably best to take Via instead or take bus services. Maybe they could do something like the weekend Niagara service where they could stop at select locations like, Bloor/Bramalea/Georgetown/Guelph/Kitchener and then St Mary’s/London. That could save at least 40-60 mins off the trip and would be more reasonable honestly.
It's too far and there's not a huge consumer base. Plus the service will be below par if they start next month.
Possibly -- but this route is worth starting from an incubation perspective. Facilitating future purchase of the subdivisions for future higher rail speeds. That's the big prize.
However, London-Kitchener commute via GO should actually competes okay with peak-period driving, and they should be able to still call this pilot a success even without Toronto.
It's political.
From a progressive viewpoint, the long-term prize is Ontario high speed rail, and rewarding Kitchener for their transit upgrades. Kitchener GO is becoming a transit hub.
So there's something in it for Cons and Libs. Transit expansions are inherently political but the venn diagram of London-Kitchener-Toronto GO overlaps both Cons & Libs & NDP long-term desires.
As I have long asserted, the creation of nominally-arms-length Metrolinx is a boon-in-disguise for transit politics. That's why Transit City still survived its cancellation, how Hamilton LRT survived, and that's why we're no longer burying subways already under construction (Eglinton subway construction cancellation in the 90s -- they actually filled in the tunnel they had started at the time). Cons does one thing, and Libs does another, but a route still gets upgraded. Before Metrolinx, transit projects were much more glacial -- the transit Dark Ages is quite notable for the few decades prior to Metrolinx's current ongoing expansions. It's imperfect and semi-inefficient but there's a lot less permanent-cancellations roulette like the Queen St subway over 100 years ago (1911 underground streetcar proposal), now finally being built with Ontario Line.
It's ugly, but alternatives are worse for Canada 2050 zero-carbon aspirations.
Cons did Libs an apparent tiny favour (indirectly) towards Canada 2050.
Now Libs have to spend bigger on upgrades to speed up GO between Kitchener-Union, now that line is extended to London by Cons. We'll see HFR and/or HSR from triparte fundings, eventually.
GO won't be much cheaper. They already charge $19.40 to Kitchener.
it's almost like it costs money to travel hundreds of kilometres.
They would need to pay me minimum wage to go on that for four hours. It seems out of touch to do this pilot... like it is designed to fail so they can say they did something but are cancelling because "there is no demand for London to Toronto service". How did Mulroney keep a straight face announcing it will take four hours?
And students. Much more comfortable than the bus and cheaper than VIA with more space. Who cares about the comfort of the seats when you have a safe train journey.
I remember years ago I wanted to take a train from Brampton to London using VIA, the tickets were around $200 if my memory is correct.
I'm seeing $42 with tax for tomorrow from Union to London. GO will likely be $10 cheaper for twice the time.
Also, ONEX Bus will get you there in 3 hours for $30.
The corridor between Kitchener and London clearly needs a lot of work if it takes 2hrs to travel. That shouldn't take more than an hour or so to cover as there are so few stops.
An hour might be optimistic without serious upgrades. But VIA used to regularly run 75 minutes. GO should be able to achieve similar.
4 hours sounds totally impractical. You can work an 8 hour day just by staying on the train.
I doubt very few are going from one end to the other, and will continue to use VIA.
In my experience, these type of milk runs, are for the stops in-between. Especially ones that VIA skips.
I too, am hoping that this is a “land and expand” strategy. At the very least, I’m excited another city in Ontario is getting hooked up to regional rail, and I truly hope for enhancements very soon to the line to upgrade speeds.
Now, where's my Bolton GO Station.
I know this is a bit off topic, but a few weeks ago YRT started a survey on transit expansion plans by 2025, and they released this updated an updated service map:
Now ignoring how... optimistic this map is, something I noticed that is a bit peculiar is this bit here:
So uh, York Region now wants to extend the Richmond Hill line to Aurora Road, and have that served by a 15 minute bus service to downtown Aurora? Ye... sure.
Good eye!
Good eye!
Its more for people who want to go from Stratford to Brampton. Not from London to Union. The Dundas sub is faster.
And dont forget it's not fun driving the 401 in the winter.
I hope that the schedule is at least a few hours apart from the morning VIA train. The speeds should be the same on the same route.
What does this comment have to do with my comment?
I was complimenting @ARG1 for noticing that York Region made a map showing the GO Richmondhill line going to Aurora Road.................
