News   Dec 16, 2025
 702     0
News   Dec 16, 2025
 567     0
News   Dec 16, 2025
 2.9K     9
Cost for the Tunnel out weights the operation cost, cost of the bridge and wasting riders travel plans from my point of view. It only takes a number of unscheduled bridge moves or have the bridge issues that the cost for delays or cancelling service adds up against using the bridge in place of a tunnel.
Sorry if this was covered in another thread, but NDP Leader Marit Stiles was recently at the proposed Grimsby GO station site for a campaign stump speech promising to prioritize the station's construction and to double track Grimsby to Niagara Falls: https://www.niagarathisweek.com/new...cle_52724e9f-42b5-54e4-9db3-eec7a26d7072.html
Not sure what reality this is rooted in given they're CN's Grimsby Division tracks...
For context, here's the current extent of double track on the Grimsby sub.
It's already mostly double-tracked, the most notable single-track segment is the 16 km between Grimsby and St Catharines. The single-track segment in Niagara Falls probably doesn't really matter since that's after CN's trains split off, and hourly GO trains would presumably lay over in NF for about about 20 minutes which still leaves enough time to get to/from the existing double track in St Catharines. A second platform at NF station (high-level platform for US customs clearance perhaps?) would be enough to enable hourly GO service in addition to Via/Amtrak thru trains.
But as others noted, I'd be reluctant to commit public funds to upgrade a line still owned by CN. Both Via and GO have been burned by that in the past.
While cost would no doubt be an issue, the suitability of a moveable bridge depends on the type of service envisioned. Bridge cycle times are long and both trains and ships need a long clearance times for safety. Not to mention ships would be passing under the bridge very slowly.
The bridge is on a dual lock along the canal that only has a capacity of about 1 boat per hour per direction regardless of the railway bridge. If hourly GO trains are timed to cross the bridge simultaneously in both directions it would have a negligible effect on seaway capacity, though it could potentially cause up to an hour of delay to ships if they happen to arrive at the wrong time.
.But as others noted, I'd be reluctant to commit public funds to upgrade a line still owned by CN. Both Via and GO have been burned by that in the past.
While the route is valuable to CN, it has plenty of unused capacity that CN may never need. I'm sure they would love to have GO pay part of the fixed costs that CN currently has to pay themselves.
It's not just ships that risk delay. Once the bridge is raised and the lock opened for an upbound boat, it takes considerable time for an upbound boat to slide into the lock. A late or out of pattern train that arrives once the bridge goes up is going to wait quite a while for the bridge to come back down.
I was looking at an older plan for a yard in Burlington, which I believe is now cancelled in favour of one at Walkers Line.
I noticed that this yard had space for a maintenance facility, which would have been the third one on the network. Since this yard was cancelled, is there still a need for a third maintenance facility?
Just about every single layover site built in the past 20+ years has room for a small running maintenance facility should they choose to build it out to that size. I think that the only exception to that is Kitchener.
This was just the ultimate maximum size of the facility should they have chosen to build it, not what they actually intended to build for day 1.
Burned? How so?
For VIA, since you're new here, I found some posts where this has been discussed before.
Also, this:
This makes me wonder about the Kitchener Line and Halton subdivision deal. The work that is being done will have MX upgrading the Halton with a fourth track in parts and a third track through Brampton. This is in CN territory, I know it seems unlikely, especially since CN probably has 0 need for more than 2 tracks, and not much more need than even one (the Halton through MIlton is single tracked with passing tracks), but isn't there a risk that CN pulls a funny and limits GO service? Potentially blocking GO operations as blackmail for more fees or whatnot? Or is there something in place that would ensure that MX effectively calls the shots on the third and fourth tracks?
There is a service contract agreement between CN and ML. It's confidential, so we don't know the exact terms, but yes one can assume it will define the number of trains that CN commits to handle. It is a legally binding contract and is enforceable. There is also federal law that gives ML the option of going to a tribunal if it feels CN is being unreasonable. It's all subject to negotiation.
Clearly on any given day, CN will care a lot more about its own operation than about GO's, and there will be some tension in the relationship especially when ML is increasing the scope of its operations. But especially where ML has added track capacity, CN seems to accept GO. The trains do mostly run with moderate reliability. And the GTA is not the only place on the CN network where passenger trains exist.
The option, of course, is to build completely separate transit rights of way. That can happen where land is cheap, but planning new rail corridors in the GTA is mostly beyond affordability. So we mostly live with things as they are. The devil you know etc.
For what it's worth, the daily CN ops on the Grimsby sub consist of 2 manifests (A421 and A422) as well as a local (which might not even be daily). Seems like plenty of room for GO and CN, similar to the MX-owned Newmarket and Oakville subs which see a few CN trains per week
Also, this:
Wow that pretty damning. I can't say I'm surprised though. It's really too bad the government didn't put in more provisions for passenger rail when they privatized CN so stuff like this wouldn't happen.
I imagine there was a legally binding service contract agreement between CN and ML back in the mid to late 2000s. Clearly didn't stop CN from screwing around as was written in that CBC article @Northern Light posted.
^ I wonder if it mentions the freight bypass research recently announced if you click on the link, or, the $6 billion idea for two new tracks outlined last year (or 2023 I can't remember).
LOL, the link takes you to IO's projects page.
I didn't spend long looking around, but didn't see any further detail that was obvious.
Even if Metrolinx owned the whole corridor, without significant track bed upgrades (and the resulting heighted speeds they would permit), I don't think hourly service to Niagara is in any way worth it. It's a 2 hour trip one way so you're still eliminating St. Catherine's commuters and I'd say the number of tourists going to the falls mid-week is minimal.
