 1.3K     6
It would be hugely inefficient for CN to have dedicated GO expansion crews sitting around waiting for ML to get their stuff together. One hears about cancellations in ML work programs because some moving part isn't ready or someone didn't know what their assignment was. Centrecourt probably fires people (and subs) for such "oops"es.
My comment about the purchase req actually originated with a guy in a CN truck at the work site that we chatted with some time ago - who commented that CN had been expecting and was ready for this task a long time ago, but ML never came through with a signature.
I did suggest Mx also would benefit from the introduction.
I'm a huge believer in government and business hiring the best at what they do to train to set up their 'system' within one's own organization so more people successfully copy the best.
Centrecourt clearly has a machine set-up; not just for the actual construction, they tend to use the same teams (planners, architects, etc.) for each job and everyone seems to know their role and the importance of delivering on time.
Generally, for the above, you can see the gap between project approval and permit issuance is generally very low, abnormally so for the industry; and then the gap between obtaining permits and work start is also very low.
While my tongue is partially in my cheek here, its not entirely. Centrecourt presumably knows little about how to build a railway; but they understand a corporate culture of organization, workflow, best practices etc; that can be taught; and Mx would surely benefit from being taught as much.
Government always going with the lowest bidder isn't always the best option. There are other non monetary costs choosing the cheapest option.
Reminds me of fast cheap and correct. Each option you can only choose 2.
Fast and cheap won't be correct, cheap and correct will not be fast and fast but correct won't be cheap.
MX probably could conduct themselves more efficiently. Problem being, it's a government run entity. So you probably have people being elected to the board as political favours with no railroad/ construction experience. You'll see their name on the sunshine list. A lot of nepotism and sycophants.
Also MX's priorities change depending on what the Premier decides are the new priorities. Causing a lot of projects to stall out. Look at the Ford government suddenly deciding that the Huronatario line requires the loop and Brampton expansion. MX is at the mercy of Doug Ford trying to save his political career.
Signal towers now up on the Kitchener second track, working on fences. Slow progress...
While this was a tweet about the Ontario Line, interesting to see progress on the realignment of the Bala Sub for the Richmond Hill line.
🐦 Drones don’t just capture photos from a bird’s eye view. They also give us vital planning information. In the Don Yard, teams are using drone footage to get a 3D map of the land which is then used to develop digital models of the site. 🗺️
[/quopte]
Oh wow theyve already moved the tracks over. when did that happen
Are we looking at the same photo?
Only one track - I hope there's contingency for a second and possibly a third, if there are service increases/starts for Richmond Hill and/or VIA Rail.
is Metrolinx still holding consultation meetings with a neighbourhood association relating to the track realignment in the USRC East? I remember there was going to be a track E0 the scope of which was then reduced but I can’t find the PDF
Not sure what you're looking at but in the photo you can clearly see that both Richmond Hill Line tracks have been shifted north to make room for the Ontario Line tunnel portal are still in place.
Pretty sure they shifted the Lakeshore and Stouffville tracks south…. Not the Richmond tracks north View attachment 545113View attachment 545114
That makes more sense, good catch Willybru.
It's hard to tell, but are there hydro lines still strung up alongside (east-west) the Don Yard, between the river and the transformer station on Sherbourne? There were slides previously put out by Metrolinx about them burying those lines for yard work, but don't know if that was ever carried forward.
Metrolinx's industry consultation for Construction Packages 2 & 4 on the Guelph Sub has reached Merx. Wish I knew the scope of these packages.
"Metrolinx is accepting [formal prequalification] Submissions for General Contractors for Kitchener Corridor, Guelph Subdivision Construction Packages 2 and 4 Associated with the Kitchener Extension Program."
