I didn't want to make too big a deal about it in the tweet, because I don't think it's that big of an issue. At the east end, there's a #20 switch good for 45 mph. But at the west end, it's either a #10 (15 mph) or a #12 (25 mph) purely based on the signalling gantry. (In theory I could've counted the number of ties to get a length measurement but they were covered with fresh ballast, and it's tricky to ballpark.) There's the obvious problem of the bridge pier being in the way, but there seems to me to be quite a bit of extra room that's going unused.So it is just a switch that has a speed limit? Is that much of an issue here? Would trains not, naturally, be going slow here anyway?
Well if they want to have a smooth rer service they're going to need to clean up their lines, including these switchesI didn't want to make too big a deal about it in the tweet, because I don't think it's that big of an issue. At the east end, there's a #20 switch good for 45 mph. But at the west end, it's either a #10 (15 mph) or a #12 (25 mph) purely based on the signalling gantry. (In theory I could've counted the number of ties to get a length measurement but they were covered with fresh ballast, and it's tricky to ballpark.) There's the obvious problem of the bridge pier being in the way, but there seems to me to be quite a bit of extra room that's going unused.
You're right in that trains would either be slowing to or accelerating from a stop, but IMO every little bit counts. Given that the zone speed drops around Snake, it's not going to make or break a timetable. But I'd certainly be interested to know what design options were considered, and what's possible given the constraint of the bridge pier. I'm just a signalling guy, not a track guy, so it's entirely possible that my nitpicking is unfounded.
Well technically RER won't be heading out this far - Its terminating at Burlington LSW.Well if they want to have a smooth rer service they're going to need to clean up their lines, including these switches
L
non-techy asking a question here...what does he mean by "shame about the low speed switch"?
Isn't this on a CN line? I wonder if CN didn't want to create the space for the longer switch and ML wanted to get something done rather than spend more time and money for the perfect solution.The reverse (curved) side of the switch has a fairly tight curvature. At least as the picture shows it looking quite tight. The tighter the curvature, the slower the speed limit for trains running through that side of the switch.
One would expect that this particular switch would be a higher speed, because the slower the turnout, the timing of the schedule will be longer and the lower the capacity of the line. Given that it’s right at the end of rhe platform, trains won’t be travelling all that fast anyways - but if the switch is the limiting factor, that’s not a good design decision.
It may just be the perspective of the photo, or there may be a good reason for it - sometimes there just isn’t room for a faster (and longer) turnout…. But with ML, one can never be sure. It’s an odd place to be pinching pennies.
Unfortunately, none of my contacts know anything about this project, so until we see the actual finished track diagrams we're all going to be guessing. (Unless someone wants to trespass and measure the frog. I wouldn't recommend that.)The reverse (curved) side of the switch has a fairly tight curvature. At least as the picture shows it looking quite tight. The tighter the curvature, the slower the speed limit for trains running through that side of the switch.
Do the numbers 20, 16, 12 have any meaning? It would be easier to remember if the switches were named after their speed (i.e. a number 45 is for 45mph).For the record, the speed limits of the various switches in CN usage are fairly variable, in the sense if they are used back-to-back (to form a crossover) they are allowed a certain speed:
#20 - 45mph
#16 - 30mph
#12 - 15mph
It is a measure of the divergence - "This divergence is measured as the number of units of length for a single unit of separation. In North America this is generally referred to as a switch's "number". For example, on a "number 12" switch, the rails are one unit apart at a distance of twelve units from the center of the frog." https://en.wikipedia.org/wiki/Railroad_switch#ClassificationDo the numbers 20, 16, 12 have any meaning? It would be easier to remember if the switches were named after their speed (i.e. a number 45 is for 45mph).
Beat me to it - thanks.It is a measure of the divergence - "This divergence is measured as the number of units of length for a single unit of separation. In North America this is generally referred to as a switch's "number". For example, on a "number 12" switch, the rails are one unit apart at a distance of twelve units from the center of the frog." https://en.wikipedia.org/wiki/Railroad_switch#Classification
Absolutely, positively, not the case.I’m just speculating, but it wouldn’t surprise me to learn that someone realised that the whole project could be greatly simplified if the signalling system didn’t have to anticipate a higher speed indication at this new switch. Or that some permutation of signal indications through some routings couldn’t be accommodated.
Just a conspiracy theory.
The signal system through there was thoroughly redone as part of the triple-tracking 15 years ago, and all of the various systems in there are all quite modern. (In fact, didn't they recently upgrade to fibre further west recently?) Changing them for track remodellings like this is not a big deal for them anymore.
