smallspy
Senior Member
Just out of curiosity, how much bigger are the GO door windows compared to the other models?
You can see it today - look at an unrebuilt car (in the old paint) and compare it with a newer car or one that has been rebuilt (in the new paint). Its maybe 8 inches taller? 10 inches?
Do any of the existing powered ramps for the BiLevel accommodate both level boarding and a step?
That's a good question. I have seen ramps, and ones that are more akin to the lifts installed in high-floor buses - but I don't know if they can manage both. In theory, the lift-style ones could, although admittedly I don't know if it is done.
I'm familiar with the level-only powered ramps. Here are some shots of gap fillers on local trains here in the Netherlands:
But these designs wouldn't support ground-level platforms.
Brightline uses gap fillers (I think they called them retractable steps, but it's the same item) on their equipment, and it's certainly nowhere as big physically as a powered lift or ramp.
But.....
It does need to get installed in an area of the car where there may not be room to fit it. There is not a whole lot of room under the floor of a BiLevel - especially at the door thresholds - and so I don't know if its feasible to fit one. The current powered lifts & ramps that I have seen mounted on the BiLevels are all mounted inside the passenger compartment and need to be swung into place (usually only about 90 degrees) in order to be activated.
