andrewpmk
Senior Member
Um, have a look at which side of the Yonge line has the Tokyo-grade crowds every morning at Bloor station. Hint: not the side leading to the "most jobs" direction. Most people in Toronto whose work can be competitively accessed by rapid transit work south of Summerhill.
If you're currently driving from a home at Morningside and Finch to an office park on the south edge of the airport, there's little chance in the medium term that a trip door-to-door using a crosstown GO line and other connecting transit would be faster and more reliable than driving. And enough other people would come to that conclusion that the train frequency would be pretty anemic, which keeps the service unattractive, and so on and so forth through the usual negative feedback loops. You can schedule alternating trains equally going to each line all you want, but it's never going to be matched by actual demand patterns.
Now, build the entire Big Move, and then build a second Big Move's worth of rapid transit lines filling out the grid, and start building a third one, and you might start getting a feeder network of rapid transit lines reaching out towards all those low-density office parks that those GO trips using the North Toronto corridor might start being car-competitive. But that's, shall we say, a bit down the road...
(Anyway, I think we're all well off-topic here...)
The Airport Corporate Centre can be accessed either using a Mississauga Transit bus that currently runs from Islington (will be moved to Kipling soon) via Hwy 427, so there will be an easy connection from the CP line to that employment area. It will also be served by a proposed extension of Eglinton LRT, which connects to the CP line at Leslie. Many of the other significant employment areas along this route also have fairly obvious bus connections.
Highway 401 traffic congestion is so absolutely brutal that anyone who has a reasonable alternative will choose to avoid it. The Eglinton LRT + CP rail corridor will attract a LOT of ridership and become overcrowded. The only reasonable way to get from Morningside & Finch to Airport Corporate Centre right now is via Highway 407, which is extremely expensive.
Also for people working in Toronto, the Yonge line can become quite packed northbound in AM rush (not as packed as SB, but definitely standing room only).
My point is that both the Eglinton LRT and the CP line through Summerhill will predominately serve suburb to suburb commuters. If we want to serve people who work downtown then expand routes that go downtown i.e. Lakeshore, Milton (i.e. the current routing from Milton to Union, not the routing from Milton to Malvern), Georgetown, downtown relief line, etc.
