News   Apr 24, 2026
 243     0
News   Apr 24, 2026
 461     0
News   Apr 24, 2026
 353     0
General railway discussions
Rail service returning to Iroquois Falls.
For a couple of years anyway while it serves the construction of the new Moosonee hospital. Hopefully, they can massage that into more permanent work.
CPKC is purchasing 135 new locomotives.
Interesting that they split the order in half.
Maybe I'm not understanding the railway lingo here but what's a "break-in-two"? Is that a breakdown? cc @smallspy @crs1026
The locomotives will feature Progress Rail’s Talos energy management system, certified by the EPA to deliver a 12.3% efficiency gain, which Progress said is industry-leading benchmark for fuel savings and reduced emissions. Powered by artificial intelligence, Talos optimizes in-train forces and has logged over four million miles without a break-in-two.
A break-in-two means the train has broken into two (or maybe more) sections, usually because a coupler knuckle breaks -or more dramatically, the entire drawbar pulls out of one end of a car.
This happens as the result of slack running in and out as the train accelerates, decelerates, and travels over changes in gradient. As trains get longer, the slack action is more pronounced. It's a major concern with trains now approaching three miles in length. There is a small amount of slack between each car, so when the trains are longer the cumulative slack action is greater. It's quite common for one end of the train to be speeding up while the other end is slowing down.
Primitive automatic locomotive "cruise control" systems may control speed as measured by the locomotive, but it takes considerable intelligence to be aware of the gradients and brake action and anticipate what the slack is doing throughout the train. No two consists will behave identically, because the brake and draft gear performance on different trains made up of different types and numbers of cars of varying weight will vary every time. Application of throttle and brake has to consider the slack and potential run in/out.
The point made in the article is that the newer systems are capable of more of this this. Without this intelligence, a human engineer is likely to run trains more safely than the computer - but it's a very mentally tiring task and requires constant concentration, so it's desirable to automate if it can be done reliably..
By the way, when a break in two does happen, the air brake hoses separate between the cars and this throws the train into an emergency brake application. Not only is this a mechanical breakdown that immobilises the train, but the emergency stop will create its own slack action that can jackknife or derail cars, or break additional knuckles. So, an event to be avoided at all costs.
PS - why does the knuckle break? It's designed as the weakest link in the train's draft gear. Better a broken knuckle than damage to the draft gear or main spines of the cars themselves. Even so, a knuckle weighs up to 100 lbs, and getting a spare from the locomotive (they carry spares) to the broken coupler, and hoisting it into place, in the middle of nowhere, is a slow and quite unpleasant task - especially in rain or snow.
A commentator in the comment section for the article appears to explain CPKC's reasoning;
CPKC is playing it smart. For the regular stuff and the auto rack trains power of choice is a Wabtech Dash 9 E Series They are fast and they are reliable perfect for pulling a container train over 12 mountain passes or through the Mexican desert. For the heavy stuff which is the coal, the ore trains, the grain, or the soda ash You need something heavier and with a lot more tractive power that is where the EMD SD70 comes in. Those engines are used to get the heavy stuff over the hill. They know what they are doing because they move a lot of heavy stuff.
Amusing how the EMD SD70's are typically used for heavy duty hauling, and yet you got Metra over in Chicago utilizing them for commuter rail. 😆
Opinions vary on which locos perform better and in what service. It's interesting to note where certain models actually end up.
The other rationale is simple - overdependence on a single supplier is fatal. The second supplier needs enough business to stay in operation. So balancing needs for certain service types and keeping suppliers healthy both factor on the decision.
And, of course, there is pricing. For both purchase and maintenance.
As a bit of an addendum to this....
Modern locos can develop in excess of 150,000 pounds of drawbar pull on the first knuckle - each.
Type E knuckles are rated for a minimum of 350k pounds of force, type F for 400k pounds of force. (And of course they can sometimes handle more than this, but this is the minimum that they have to be rated for.)
So looking at the numbers you can see that 3 modern locos located at the head end of a train can easily develop enough force to rip a train in half. This is a large reason why DPUs have become so prevalent - longer trains means more weight. The locos have kept up with the size trend, but the couplers have not.
And one of the advantages of DPUs is a reduction in slack action because you now have a loco in the middle of the train adding its propulsive and braking forces to the whole. Slack doesn't pull out like it used to with all of the locos at the front, and it doesn't bunch in under (dynamic) braking, either.
DPU trains (remotes in middle & tail) are Ferrari's compared to a conventional train (all locomotives on head end). As engineer, it's important to know the make up of your train, and when and where to manage your slack carefully. There are certain well known locations where dips in the sub are located. You want to approach those below track speed and accelerate so you stretch your train out, pulling out the slack and pull it through the dip. You can bet your conductor will be giving you the eyes if he feels rough handling and will start putting on his outdoor gear (lol).
You need to think miles ahead, especially for temporary slow orders, which can appear anywhere and are identified on train docs. The last thing you want to do is forget about one and have to go heavy on the brake. All control inputs need to gradual to avoid excessive force. It might sound easy but factor in different train make ups, power configurations, weather conditions, mechanical issues, sleep patterns, radio clutter, poor planning and the job gets intense.
A very northern railway.
Once completed, the Steensby Component will enable production at Mary River to increase from approximately 4.2 million tonnes per annum to 22 million tonnes per annum in approximately four years. Baffinland’s high-grade iron ore will be transported by rail, south to a new deepwater port at Steensby Inlet, eliminating long haul trucking to Milne Port, significantly lowering production costs and environmental impacts, and optimally expanding the shipping season to deliver product to markets worldwide competitively.
News release from today.
Map from from an X post where someone posted the media release.
Interesting. I didn't think they would go through with it, much like early Ring of Fire proponents talked about rail then it died off.
Interesting that this image shows a shipping route to Churchill, but the EA documents show a shipping route out to the Atlantic. They know how to read the room.
This mine has such high grade iron ore that it needs no processing beyond crushing.
Shipping will obviously be seasonal, but cold weather operations will probably make VIA's problems pale.
What I heard is that when the ownership changed in 2010 to a US private investment firm, the new owners reneged on the promises and hiring deals with the local Inuit, who then wouldn't approve any expansion to the roads and facilities on the north side. So they went back to the railway. I hadn't realized that the shipping route was to Churchill.
How any ownership thinks it's okay to screw over the First Nations and Inuit - especially in Nunavut - I don't know. More reason to ban US ownership of our natural resources, and for First Nations and Inuit not sign deals with business, without government guarantees.
I suspect the shipping route will be be to wherever the buyer is. My comment was showing a conceptual shipping route to Churchill simply acknowledged the ongoing politics. Putting the ore on a bunch of trains, then onto a ship, then back onto a bunch of trains to ship it to some steel plan that is nowhere near Churchill seems inefficient. If it was destined to a Great Lakes steel mill, putting it on a Great Lakes-sized ship at leaving it there seems more practical.
If you have a small window to ship ore, putting it on larger ships makes more sense.
Remember, both the Great Lakes and Hudson Bay freezes for around the same length of time, at the same time.
If it were feasible to extend a line as close to the island on the mainland, that would make it even better. I doubt there is enough ore to warrant even looking into it.
