drum118
It was still that way a month ago when I had a look at it, but never shot it since it was the same when I last shot it.That's been like that since at least December...
.No different than what you find in Europe or the US with many platforms having nothing at all on them.
This is why our capital costs are going up. Those structures are massive for the (small) amount of weather protection they provide.
If we are accepting the common “minimal weather protection” as the norm, then a few traditional bus shelters would save a lot of money. Conversely, if we are demanding structures with that much steel and concrete and conduit per linear foot…. then they ought to be built to maximise their benefit.
I concur. I don't have difficulty with spending extra $$ for weather protection or amenities or aesthetics (to some reasonable limit). But, if we're going to do that, I want effective weather protection, drinking fountains/vending machines/washrooms, and something as close to 'objectively' attractive as one can manage.
To spend the extra dollars and achieve next to none of that is, at best, wasteful.
Hey, Here on UT, mentioning the need for public washrooms in the context of transit stops is pretty close to trolling ;-)
If we find we need better shelters, retrofit them down the road.
Washrooms are long over due especially in the west end, let alone the system.Ahem, ............ washrooms are bieng added to Osgoode Station and Pape Station as part of the O/L project already.
Of note, the TTC has quietly changed its policies on washrooms and now wants them built into ALL new or deeply retrofitted stations.
Trolling can pay off.....
In the case of fixed rail projects, you pretty much need to determine the width of any platform and, of course, the choice to go side or island right at the beginning of the process. Likewise, running any lighting, heaters, cameras, or vending machines requires laying electrical conduit under any concrete/paving etc during reconstruction, digging that up to add it later would be costly.
Sure, we could install something more modest in scale initially and actual heaters or vending machines could wait, but the 'plugs' for them can't.
You also need the ability to support w/e ultimate structure you want. So I'm not sure there's a great deal of advantage to skimping.
These are still in use, just only in curbside stops.the early VIVA bus shelters
They won't be able to call it the world's longest bathroom without plumbing if the TTC actually follows through!Of note, the TTC has quietly changed its policies on washrooms and now wants them built into ALL new or deeply retrofitted stations.
If TTC does the stop and go on any switches on this line, time ML to tell TTC to forget that idea and run the line like others systems in NA and Europe. Have ridden far too many LRT lines with switches and not one of them stop or slow down for them.Not sure if this was mentioned/discussed on here. I was watching a video from Reece the other night and reading the some of the comments, one that stood out was that this line will be employing a block signalling system instead of ATC that will be used on the Crosstown. That and the TTC will be enforcing their antiquated stop-and-proceed operations over special trackwork on a 21st century modern LRT line![]()
