News   Apr 20, 2026
 192     0
 2K     6
Eglinton East LRT | Metrolinx
yea catalyzing new development is the only metric where LRT performs way better than BRT, though far more urban developments are already being proposed along the route regardless of transit options so i dont think it enough to affect the decision. A line 4 extension would certainly bring plenty of new development to Scarborough.
"way better" is probably an exaggeration. Look at what York Region was able to pull off with BRT running every 30m 🤣
I been saying that they need to grade separate the Kingston Rd, Lawrence and morningside intersection. Remove some left turns and use two stage crossing. Figure out how to implement transit priority before building.
this is what I'd vote for. Scarborough would greatly benefit from this.
I am catching up over the past year's worth of posts in this thread and this below, wow.
At least part of the Eglinton East LRT would follow part of the former Kingston Road Radial line. Note that the radial line was on its own right-of-way. When they abandoned the radial line, they widened Kingston Road paving over the right-of-way to make for more lanes for the automobile.
They should post the old Kingston Radial "stop numbers" on the LRT stops along Kingston Road. If we can find historical references to the stop numbers.
So you are telling me they figured this out in Toronto a century ago. Progress truly is not always linear.
I wonder if the best solution to Eglinton East LRT, rather than trying to recreate the Eglinton-Kingston-Morningside route, is a combination of the McCowan-Eglinton infill suggested by @Northern Light (no doubt by other people as well) and an upgrade to Lakeshore East GO, with an improved connection at Danforth GO for Line 2 transfers. Spend some time with the remaining RapidTO lanes and work out ways to smooth the bus flow through the chokepoints.
Of course, we would need to avoid a reprise of Smarttrack and the Railpath's questionable accounting. But even if this thing runs 20 km/h, which seems questionable with the TTC hanging around, it's not a lot of travel time improvement for the cost, and it just does not justify the cost of grade separation - GO is half the travel time from Guildwood to Main Street, which would be a good connection if only the frequency was every ten minutes or less instead of thirty.
The downsides to this late night crayon are Malvern and UTSC. Malvern could conceivably be served by adding the 133 Neilson and maybe the 131 Nugget to the 10 minute network. I will admit that I have no solution for UTSC off my head. Otherwise, riders headed to Eglinton or local destinations could continue to ride the bus while those going anywhere west of ~Victoria Park would transfer to GO.
No doubt I will wake up tomorrow morning with another even crazier "idea".
That would speed up that one turn and its definitely the better design option than at-grade for that intersection, but it addresses the main issues with the line. If they grade separated a bunch of major intersections like that and removed a lot of left turns and through traffic at minor ones, you could start to see some real improvement, but that starts to get expensive
I so wish they built a station at Eglinton and Brimley. I believe an Infill station was not accounted for and would be very difficult to add. On top of serving a busy and dense neighbourhood with good development potential, it'd shorten a lot of bus trips coming from the east and make it so you don't have to backtrack to get to STC on the subway coming from Eglinton East.
DLR style elevated mini metro with several branches to connect to UTSC, Centennial College, Malvern Centre, the zoo, and back to Scarborough Centre.
  • DRL style 100m trains is overkill. I am thinking of 40m train Canada Line (Vancouver) style.
  • Basically following the Eglinton East route, but elevated.
  • Kennedy is a major interchange with Eglinton LRT, GO, B-D, and EKUMA (Eglinton-Kingston-UTSC-Malvert-Agincourt).
  • EKUMA is 18km, 14 stations. $5.5 to $6B.
  • McCowan/Sheppard (can't come up with a good single name) is another major interchange with Sheppard, B-D and EKUMA meeting.
  • With several options at these 2 interchange stations, it will not be an obvious situation of a linear transfer.
  • Phase 2 would be a line following the SRT route, and includes an Ellesmere GO, as well as 6 other stops. It could be extended East along Ellesmere.
  • For the zoo, the only option would be a 2.5km gondola from Morningside/McLevin (or half that if zoo admission needed to take the gondola and it drops you in the North America exhibit in the valley).
  • I also secretly want to extend B-D at grade to Finch/Markham road and acquire some of the CPR yard as a maintenance yard for the B-D (and for EKUMA).
So, for about $1.0 to 1.5B more than the current $4.5B estimate for EELRT, we can get something that will actually work and convince people to take transit vs. car.
Given where I live something like this would be the dream and extremely transformative. Unfortunately, I don't ever see it happening. More likely to see Sheppard subway go further east than currently planned..
I am already having second thoughts about the Phase 2 that I drew. Maybe Malvern is already served and either a straight elevated line along Ellesmere to UTSC is best, or maybe a BRT corridor that is also used by Durham.
But you actually raise a good point. Sheppard subway going to Malvern instead of McCowan would likely cost $1B+ more.
So, it looks like it is basically cost even.
Sheppard Subway to Malvern + a 27 stop 18km long on-street LRT,
OR
Sheppard Subway to McCowan + a 14 or 15 station 18km long elevated mini-metro,
It's too late to fix Finch, and Eglinton through Golden Mile (even though some tinkering may make minor improvements) - but we may as well admit our errors and start doing things right.
We already have a thread dedicated to transit fantasies.
Most of the above has little to do with any EELRT proposal that is moribund, and going nowhere, and that's as it should be.
Take fantasies to the correct thread please.
