golodhendil
Active Member
^Thanks SlickFranky. I guess someone was too angry to read properly.
the question is whether icts can handle snow/cold. does icts always suck, or is it just ours that sucks?
For the usual stated problem with ART (snow accumulating between the guide plate and the train's motor), I don't see how surface vs. elevated makes much of a difference. In any case, Detroit is all elevated, NYC has both surface and elevated, and Beijing has both underground and elevated.With other ICTS cities, we have to consider if their lines run on the ground, elevated, or in tunnels. The SRT does all three (though the tunnel is short) and I'm not sure if the snow problems are worse on the surface sections in the middle of the line near Ellesmere and Lawrence or on the elevated stretches at each end.
December 2008? I remember hearing reports of Skytrains closures ... and I can still find a few on the web ... including one - http://www.cbc.ca/canada/british-columbia/story/2008/12/21/bc-snowstorm.html - where they had to delay service because the doors to the cars were frozen shut ... even though the low that day was only-6.6°C (though to be fair it did get down to a low of -15°C the day before ... but that's hardly cold by Toronto standards).Last year Vancouver took a pounding of snow, a whopping 100cm in 3 weeks.
Then that, obviously, is not a property of surface vs. elevated tracks, but of the local surroundings of the guideway. An elevated track running high above a highway median through lowrise neighbourhoods (NY) would already have very different snow conditions than another elevated track running between skyscrapers (Detroit). Heck, even different wind directions or speed would affect differently how fast snow accumulates. It would, of course, be interesting to see if any such stats are available for which sections are more prone to problems, if there is any pattern to it.You don't see why a track adjacent to fields and parking lots might end up with different snow conditions than an elevated line? Once again, I'm asking where the problems are worse on these lines. If even trace amounts of snow cause problems, only then does it not matter since any outdoor stretch will be affected.
As for the amount of snow/ice that will cause problems, that is part of my question. Given that the 1-cm separation between the plate and motor is always brought up, one would assume that accumulation of that scale would already pose problems. The question is (and that's a genuine question), whether that is something that could be solved by continuous operation, track heating mechanisms, etc.
