News   Aug 12, 2024
 402     2
News   Aug 12, 2024
 1.5K     0
News   Aug 12, 2024
 536     0
Barrie Collingwood Railway (BCRY)
Is there public confirmation somewhere this will use BCRY? That would be great.
It was mentioned in the draft plan than Ram Iron and Metals intends to do so.
Doesn't even have intercity bus service other than the Linx bus that doesn't even run on weekends. The mayor's of those cities should be ashamed of themselves.
Mind you, I don’t have the documents handy. But documents (specifically the transport master plan) did show the county was interested in the idea of running service between Barrie and Collingwood via Angus, New Lowell, Stayner, and Batteaux. Unfortunately, it doesn’t seem like it went anywhere; maybe there’s this idea that Metrolinx is supposed to handle rail?
The old ROW forthe Newmarket Sub between Washago and Barrie,are there actually any structures in the way of it?
Yes.
73 Barrie Terrace directly in the way ... all the homes on Barrie terrace would also now front onto the railway instead of a road. So that is like 25-30 properties.
All the properties on Barrie North Shore Trail have the same issue (front onto a new railway) - that's another 10-15 properties.
3351 - 3267 Ridge Rd W also directly in the way.
Would also require major reconfiguration of Lakeshore Dr / Simcoe st to get around the Bay, plus change access to all the Lakefront Parks and Marina.
Yes.
73 Barrie Terrace directly in the way ... all the homes on Barrie terrace would also now front onto the railway instead of a road. So that is like 20-30 properties.
As seen below:
The red flag on the map above.
Agreed.
While I think restoring the old alignment is feasible (if requiring many millions in expropriation and the works you note above)
I think those obstacles do make a good case for considering an alternative alignment going north.
Yes.
Lakeshore Dr. (and probably Simcoe St.) is actually on the old ROW. It was moved back from the shoreline to improve the park area and parking.
There is also the Home Hardware in Orillia, plus slices of several properties along Atherley Rd., as well as Casino Rama.
In the fantasyland category, there's two old right-of-ways from Orillia intersecting the CP McTier sub in Medonte that would be far easier to reactivate. You know, once Bolton gets GO service... :)
Edit to add: Or just slightly more realistically from GO Allendale Waterfront via a reactivation of the North Simcoe Rail Trail to CP McTier. It's so easy to fantasize on Google Maps...
