News   Dec 08, 2025
 102     0
News   Dec 08, 2025
 153     0
News   Dec 05, 2025
 1.3K     5
Alto - High Speed Rail (Toronto-Quebec City)
An HSR station at Sheppard and McCowan would have almost as many connections as Kennedy if/when the Sheppard extension is built. You could connect to Lines 2 and 4, and the Midtown line if CP agrees to share its track, and perhaps eastward GO connections towards Pickering as well. There wouldn't be a northern connection, but there could be buses (and I think there's potential for a busway north of Sheppard/McCowan.)
If Metrolinx is involved, it could take 50 years after Alto opens before they built the connection to the subway (which is about how long the Bloor-Dundas West connection has taken since Bloor GO opened). So about 2090? 🤣
I wouldn't be surprised if by then Line 2 goes further north of Sheppard by 2090. There's already some density at Finch, and plenty more potential. And then again at Alton Towers, south of Steeles. Maybe one day it can get to the 407 transitway, Highway 7 and then Centennial GO!
I've always thought any HSR using the Don branch to get into Toronto made little sense. Those lines are much better suited to local service, and putting high speed trains on those lines severely limits their use for local trains as only two passenger tracks will fit.
I would use LSE up to Ajax, then build new tracks roughly next to the 412/Lake Ridge Rd up to the Havelock Sub (or wherever the HSR alignment is)
There's lots of advantages to this:
- Does not use any lines which would be better used for local service, and few conflicts with local trains
- Avoids building the big bridges over the Don
- Synergistic with GO LSE electrification, track improvements etc.
- HSR trains can stop at Scarborough Jct and/or Pickering which are probably better than Agincourt
- If/when HSR services cause too much of a problem with local LSE services, the corridor can be expanded to four tracks fairly easily with some fairly small structures plus some realignment of the GO or CN tracks and/or 401 ramps in Ajax. Then, HSR would only share tracks with express services, which due to high average speeds much closer to HSR and lower frequency would be fairly straightforward to timetable. Express services would only make ~2 extra stops than the HSR, which combined with longer dwell times for HSR would result in very similar average speeds, and therefore high capacity utilization.
The only down side that I see to using the Don route is the need to build bridges. Yes, more expensive, perhaps.....but after deciding to spend liberally (pun intended) on double track all the way to Quebec City, is that cost element a showstopper ?
I have more concern that Alto going along the Kingston (and either up the Stouffville route, or a new alignment further east) is bolting on to (and forcing further redesign and rework of) a GO Expansion system that was designed with a certain capacity for commuter and regional service. Adding Alto puts the squeeze on that. Whereas using the Don Branch gives Alto its own, unencumbered routing into downtown Toronto and on its own rails. Are we really happy with putting so many eggs in one basket ? ML seems indifferent to VIA today, how seriously will they support both HSR and legacy VIA service on the Kingston Sub?
The Kennedy route seems to imply speed limiting curves at Agincourt, and again at Scarborough Jct.... and doubtless a less than optimal speed between Agincourt and Kennedy, even with new tracks added, Whereas a Leaside route could support HSRish speed much closer into the city. Again, it seems odd to accept a constrained speed and hence longer timimgs on the Toronto access after going to the max the rest of the way.
The tunnel under the 401 will be almost as expensive as a bridge over the Don.
As to Pickering-Ajax-Oshawa - do not discount the need to unbundle CN freight and legacy passenger before scheming to build HSR tracks. The obvious first step would be to extend the York Sub further east, restoring the ability for freights to pass in this area (requiring a bridge span over Duffins Creek) and then a flyover to route VIA to the north side of the row to reach Oshawa station without level crossing of the freight path.
There will need to be provision for regional service, probably GO taking over the VIA legacy service which Ottawa seems quite happy to sacrifice. I would imagine this will eventually demand new track construction eastwards from Oshawa, perhaps sharing with CN but more likely dedicated regional rail.
(There are likely more autos using the 401 to reach destinations along the Cobourg-Belleville-Kingston path than through drivers to Ottawa and Montreal. I am determined to tenaciously make noise about the need for enhanced legacy service on this route, up to and including hourly or bihourly service all the way to Kingston, to seize this modal share. Alto should not be allowed to preempt this regional system, it is equally important).
I would be far more dismissive of the whole Kennedy idea if the suggestion was coming from anyone other than @Urban Sky , whose detailed knowledge and inside insight into the actual planners' thinking exceed all us other posters. So maybe this is truly what is planned and should be taken very seriously. It may be doable, but it seems like an odd place to pinch pennies, and is the inferior route, to this guy in the bleachers anyways.
If you start throwing in stations left right and centre you're going to get the exact same problem as line 5 with over saturating the line with too many stops. Union Station should be the only station in Toronto. Next stop east should be pickering or Oshawa. GO is the limiter express feeder service for the hsr followed by the subway for local.
Dont use hsr as a go train/subway
Disagree. Other large cities have multiple large stations. If we use Union for HSR we create even more of a pinch point and stress point if we only have one station and rely on it for everything.
which one if i may ask? Ive checked ICE and TGV.. None utilise 2 stations within 20km of each other on the same line.
High speed rail doesn't work like an LRT line. Not every train stops at every station.
HS1, KTX. They run commuter trains on HS1 - continental services seldom stop at intermediate stations. All sorts of stations on KTX served by local services.
More than enough capacity on a 2-track (!) Alto service to run high-speed commuter trains to Peterborough.
HSR will be going much slower than high speed through Toronto. It can make sense to have another stop in Toronto/GTA. It's not as much of a detriment.
Having infill stations available to be built isn't a bad thing, but that doesn't mean that all trains need to stop.
The HSR egg literally just got fertilized and youre already trying to run outside the womb....classic scope creep ambitions. Let's sort out the actual intercity hsr lines before talking about high speed commuters to replace GO service.
Besides, last I saw people here on UT typically spurn Asian methodologies.... whats changed?
Geezus... check the message logs... im not the one who got so offended by an innocuous comment in jest about ut foamers spurning asian countries.... grow a spine
I apologize. I hadn't realized your false comment about European HS lines not having stations every 20 km was a jest.
I didn't create a distance barrier to solidify my point - just saying that we shouldn't be afraid of having more than one station, particularly with the introduction of HSR.
You may want to count the number of ICE stops in cities like Munich, Frankfurt, Dresden, Cologne, Basel and especially Berlin or Hamburg:
Here a fairly typical example with 3 stops each in Hamburg and Berlin:
