News   Feb 13, 2026
 2.4K     5
News   Feb 13, 2026
 4.2K     1
News   Feb 13, 2026
 4.9K     0
Tips To Avoid Housing Bubble
realityjason
New Member
Buying a a property is like buying a business. Nobody wants to pay too much for a business that generates only so much profits. Similarly, we need to think rationally about a property from an income approach, just like how the bankers think about a business.
You may ask: what if I'm buying one for my own use? The answer is: you should treat the home you're buying like an investment property equally. The key idea here is you want to find out the fundamental value of a home. And history tells us that all properties and assets go back to its fundamental value sooner or later. That means, relying only on speculative values set forth by people in real estate market can cost you big discount of your net worth later when property values really adjusts. Unless you have couple million dollars sitting in your bank account, the chances are, you care about your net worth. The bottomline is you don't want to pay too much for what a property is really worth fundamentally.
Owning a property gets you a series of rental income. So the income approach actually makes you think backward: For the rental income that you're getting regularly, how much would you want to pay for it? Savvy investors and bankers know that we can employ the so-called Discounted Cash Flow (DCF) method. We're not going to take 10 pages to discuss it. But the key point here is, you want to compare the fundamental value (we call it Rent-Implied Home Value) with the selling price out there to determine if it's a bargain or not.
If your property value deviates largely from your Rent-Implied Home Value, beware! This is a strong evidence that your home value has large bubble content.
Some of the tips to avoid getting caught by bubble are:
1. Check how much is needed to maintain the gross rental income
People who are familiar with Rent-Implied Home Value concept may try to inflate it by hidding the ongoing costs needed to maintain the grosss rental income. Two properties may get you the same rental income, but one of them may cost you whole lot more to maintain.
2. Check how reliable the rental income is.
Yes, we acknowledge that there is vacancy risk. The vacancy rate actually tells you the fair probability that you can get your property rented. Be sure to find out the long term one.
3. Be sure to check if the rent yield is larger than Treasury bill's rate
This may sound technical. But it's important! Rent yield tells you how much return you're getting from your property. If it's less than T-Bill rate, why would you want to invest in this risky property in the first place when you can get more return risk-free?
4. Collect the most accurate rental and costs information
Accuracy depends on your dilligence. Garbage in, garbage out. Simple as that.
Fortunately, you don't need to crunch all that numbers by yourself. <a href=www.houseminers.com>HouseMiners.com</a> does most of the work for you, free of charge.
Next time you buy a property, remember, check your Rent-Implied Home Value.
It is well known that housing buble in US was born after Greenspan kept interest rates too low for too long. The very same situation is taking place in Canada. I understand that government is trying to cure economy, BUT why not oblige banks to lend ( residential mortgages only)at prime + 2 or 3% to deflate housing bubble here, besides don't banks need additional capital? This extra few percent would be helpful.
Completely wrong. The reason there was a bubble is because banks were deregulated and allowed to lend to people who couldn't afford any of the loans. If every one could afford the low interest rate mortgages, then it wouldn't be a bubble would it.
The banks were not deregulated as such in Canada. Low interest rate will encourage spending though. In this kind of economy encouraging spending is needed to save from bigger problems.
All I'm saying is that low interest rate is not reason alone to have caused a bubble...
The real reason behind the bubble was; equity to debt ratio was practically nothing, and there was no debt service ratio to speak of. Low interest rates only amplified the effect.
For instance, let's say if all loans consisted of 30% equity, and interested was fixed at .5% for 10 years. Furthermore debt service ratio was 1.3. Would there have been a bubble? I'm inclined to say no... Hence low interest rate alone is not cause enough to create a bubble.
If this doesn't make sense, then nevermind.
