3Dementia
Senior Member
Designer: Peter Bowyer
Bridge Type: box truss
Project Description: see below
Poll: attached
Images: attached
DESCRIPTION
Project Name: Worm
Worm is an idea for an unusually long sculpture that will span over three hundred feet of
railway gorge in downtown Toronto. White panels bolted onto a floating frame of
galvanized steel, encase a pre installed box truss pedestrian bridge. Optically complex,
the piece weaves positive and negative space into a horizontal stretch pattern. Viewed
from the outside, the movement of pedestrians and bicycles across the sculpture should
produce an animated flicker. Traveling on the inside, the structure will create a
kaleidoscopic experience of light and shadow. The panels will allow fragmented amounts
of shelter from extreme weather during the day and lighting opportunities at night.
Functioning as an animated three-dimensional banner for arriving trains and a welcome
boulevard for cyclists and pedestrians.
The box truss bridge would be a standard design, slightly reinforced for weight and wind
load. The sculpture encasing the truss bridge would be made from galvanized steel and
sealed plywood, using the same engineering and weather proofing standards that are
found in highway signs and billboards. Open sections of the bridge may need to be
closed off in areas with Plexiglas screens. Standard building and municipal codes would
direct the design of all ramps and railings.
IMAGES
Poll: attached
Images: attached
DESCRIPTION
Project Name: Worm
IMAGES
![01worm.jpg](http://www.upside-down.ca/submissions/01worm.jpg)
![02worm.jpg](http://www.upside-down.ca/submissions/02worm.jpg)
![03worm.jpg](http://www.upside-down.ca/submissions/03worm.jpg)
![04worm.jpg](http://www.upside-down.ca/submissions/04worm.jpg)
![05worm.jpg](http://www.upside-down.ca/submissions/05worm.jpg)
