Northern Light
Photos taken March 29, 2021:
We'll start our tour at the top of the stairs as they descend from Kingston Road:
This is a long set of stairs:
Here, we continue to see the stairs, but also the pathway at the ravine bottom; to the right are some native Hemlock trees planted by Urban Forestry as part of on going restoration works:
The green dot on this tree (an Oak) is generally indicative of something having been done to the tree to help it. You often see this when Ash trees are vaccinated against the borer.
But in this case, the Oak tree was being given a hand to deal with Fall Canker Worm:
As we arrive at the base of the stairs, there is a small brook which forks there, along with the path, one branch going to Kingston Rd, the other to the east and Beech Avenue.
This is a look up the branch heading to Beech:
Same as above, but focused on the brook, not the path:
Now we're looking south, along the brook, running parallel to Glen Manor Drive:
Want to know how much damage a falling tree can do?
Well, this one fell over:
As you can see, it made 'an impression' on the metal guard rails of this little bridge:
Now, another look at the brook as we continue southward: (you'll note a few leaves still on trees, Beeches, Ironwoods and Oaks often hold their leaves through winter)
Here, a lengthy boardwalk begins, this helps keep people out of the muck, as the valley bottom here is narrow and wet, it also reduces erosion from people not scrambling to dryer, higher ground:
This little brook originates over by Balsam Avenue:
To be con't
To be con't
